Running Acorn Lathe Ultimate on Lathe
When I push 100% it decreases spindle RPMs.
Since it started doing this it is also not reading my encoder correctly I. The software and reads +215 but the lathe is actually running at 2200 on it’s readout!
Thoughts?
Encoder bad?
Auto Spindle
- CNC Control System Serial Number: E8EB1128AAC4-0405180824
Auto Spindle
Re: Auto Spindle
The 100% key commands 100% of programmed (via an Snnnn) command, or 50% of maximum speed if running in manual spindle mode.
Re: Auto Spindle
Is your spindle encoder showing any errors on the PID screen?
Re: Auto Spindle
post a fresh report.zip
Re: Auto Spindle
I have attached report.
- report_C8FD19D3C3E1-1109170238_2024-03-16_09-14-28.zip
- (1005.58 KiB) Downloaded 3 times
