Tool touch height
Dholman
Tool touch height
Post by Dholman »
Everytime I enter the height to be subtracted in the wizard and save and close the wizard it goes back to zero and does not subtract is there a specific order that needs saved
Re: Tool touch height
you'll have to post a fresh report.zip
Dholman
Post by Dholman »
here is my report
report_780473845840-0206191632_2019-05-22_11-33-19.zip
(315.44 KiB) Downloaded 115 times
ok...i confirm.. so as a work around.. go to cnc12 and set Parameter 71 to a negative value of the TT height device and it will stick..
then you don't have to worry about the wizard resetting to zero
Dholman
Post by Dholman »
That worked thank you
