Hello, Noob here, and possibly dumping M4 to go to Acorn.
in the CNC-12 programming,
Is it possible to have an input switch directly drive one (or 2) of the output relays directly?
Can one input drive 2 relays at the same time? (if i needed a DPDT, using 2 of the SPDT relays)
Same as if it was a toggle switch directly wired to the coil of a relay?
Thank you for the help and input.
Input directly controls an output relay <Answered>
Re: Input directly controls an output relay
Sure, no problem
