USB-BOB Housing
Helinut
Re: USB-BOB Housing
Post by Helinut »
Suntravler,
I have my USB BOB up and running all functions and Led's work except the MPG'S. I have them each assigned to an axsis 1-3. I have checked the wiring several times and I have 5 volts at the MPG terminals.
any thoughts on what I may have missed?
Wayne
Re: USB-BOB Housing
Do you also have a WMPG?
Helinut
Re: USB-BOB Housing
Post by Helinut »
Yes I disabled it in the wizard.
Helinut
Re: USB-BOB Housing
Post by Helinut »
It is probably the wireless usb antenna that is still plugged in.
Re: USB-BOB Housing
You can have the WMPG enabled, but set to spin or feed and then switch on MPG on the VFD.
RogDC
Re: USB-BOB Housing
Post by RogDC »
You can use the WMPG with the BOB, however you cannot jog with the MPGs on both simultaneously.
The WMPG MPG wheel is selected when WMPG is powered on by default in CNC12 5.2x.
When you have the WMPG turned on, the WMPG icon button should be visible on the VCP.
Turn off power on the WMPG, on the VCP the MPG button ( not the WMPG icon ) will be visible, enable MPG ( red LED On VCP ) and you should now be able to jog from the BOB.
I just power off my WMPG. I wasn't aware of Uwe's suggestion of setting the WMPG switch to Spin or Feed for the BOB MPGs to be able to function.
The BOB also has a MPG Toggle input which you can toggle the MPG on/off from the BOB. You could add a momentary switch or use one of the FEED/SPEED/SPINDLE encoder switches set in the Wizard as an MPG toggle. I have a MPG Toggle button and indicator on my BOB control.
Helinut
Re: USB-BOB Housing
Post by Helinut »
Thanks,I was not aware of the MPG toggle. All is working now.
Black Forest
Re: USB-BOB Housing
Post by Black Forest »
Thank you Uwe for the detailed pictures of how you wired in the resistors.
