USB-BOB Housing
USB-BOB Housing
Fusion and Step files of my USB BOB housing
- USB_BOB.zip
- (398.7 KiB) Downloaded 8 times
6 users liked this post
Re: USB-BOB Housing
The momentary push buttons are 12 and 16mm:
https://www.amazon.de/dp/B0B3QJGNG7/ref ... RhaWw&th=1
LEDs are 5mm:
https://www.amazon.de/dp/B0849PF9JS?ref ... asin_title
https://www.amazon.de/dp/B01M4RUY4M?ref ... asin_title
Resistors form a set like this:
https://www.amazon.de/BOJACK-Carbon-Wid ... r=8-1&th=1
4 Terminal MPG:
https://www.amazon.de/dp/B07MFVK8QT/ref ... F9kZXRhaWw
Terminal block:
https://www.amazon.de/dp/B0DHQZ88F8?ref ... title&th=1
LEDs are 5mm:
4 Terminal MPG:
Terminal block:
1 user liked this post
Re: USB-BOB Housing
Nice Job! I have been thinking about this. Do you find that you have better control over the mill for manual milling than if you were to use the MPG?
Re: USB-BOB Housing
Double post.
Re: USB-BOB Housing
Thank you for posting your sources for the parts. That is a huge help. Now I just need to find someone to 3D print the box for me. Did you print the face red face plate?
Re: USB-BOB Housing
I can print one for youBlack Forest wrote: ↑Sat Dec 14, 2024 6:03 am Thank you for posting your sources for the parts. That is a huge help. Now I just need to find someone to 3D print the box for me. Did you print the face red face plate?
Re: USB-BOB Housing
I have the BOB with the WMPG together.
IMHO the machine is faster to setup with the BOB.
Re: USB-BOB Housing
Where are you using the resistors you listed in your parts sources? Is there a wiring diagram with all those parts in it? Thank you for the offer to print the parts. I won't do anything until after the New Year. No time right now to get into any more projects. I had a trash container delivered this week for all the unfinished projects in my shop. I am being ruthless in clearing up my shop. Two containers actually. One for metal and one for normal stuff.
Re: USB-BOB Housing
The resistors are for the LEDs, the values for different LEDs are in the BOB manual.
Re: USB-BOB Housing
Here is where the resistors are used and the current state of my BOB.
I have changed some functions to fit my workflow better and my first design was in a very early stage of the beta version.
