Accessing Wizard tabs in CNC12 V4.5
Re: Accessing Wizard tabs in CNC12 V4.5
and post link to photo album of the machine and all its accessories so we know what we are working with here!!
Here is the report after starting to configure cnc12 v5.10. I am not sure what to do about the ZRI inputs for the home sequence. I also tried to reset Home and was given a drive fault. I will get some pictures of the machine for you.
- report_F045DA7F9063-0111191533_2024-08-28_08-48-11.zip
- (1008.21 KiB) Downloaded 1 time
SO, when I was going through pictures of the machine to post I found the screen shots and notes I made when first converting the machine back in 2020. I went through wizard and got everthing put back in. I think I am moving down the right path know. I was able try to home the axis's but there is no movement in the drives or so it seams. No drive faults. Attached is report after the changes I made according to my notes from 2020.
- report_F045DA7F9063-0111191533_2024-08-28_09-21-10.zip
- (1007.8 KiB) Downloaded 2 times
you don't need to define an input with any canned functionality to use it, there is a good zri example in the macro programming guide, use that
need photos
Here is some pictures of the machine and the control
More pictures of the control
Last of the controls
Here is a layout of my cabinet.
Please start a Google photo album and put all your photos in there and then share a link her. This way ALL your photos are in one place and easy to find and navigate them when they are ALL in one place.
See this topic on how:
viewtopic.php?f=60&t=1043&p=5010&hilit= ... lbum#p5010
