Accessing Wizard tabs in CNC12 V4.5
I am upgrading CNC12 from V4.5 to the current version of V5.1 as recommend. I watched the video and I am going through and taking screen shots of the wizard screens to make things easier for me. I am unable to open the screen tabs for Primary system which includes Axis drive type, inputs and outputs definitions. I remember the screen when I installed ACORN original but that has been awhile. What am I doing wrong or is there another way to get the same information?
- report_F045DA7F9063-0111191533_2024-08-26_13-04-58.zip
- (774.6 KiB) Downloaded 4 times
Re: Accessing Wizard tabs in CNC12 V4.5
In the wizard menu once it's opened on the left side of the page you can just click on "input definitions" and "output definitions" to see each screen. Not sure why you cant. Are you saying nothing happens when you click them?
I am saying exactly that. Nothing happens and it even appears there is not hyperlink associated with them. My cursor doesn't change from a arrow to a finger. I feel like the machine is giving me the finger
the report.zip has all the info you need.
install the latest CNC12 either the release or the v5.19 beta and configure the Wizard and never look back.
Z 10.2380 8000
X 12.6986 8000
FirstAxisHomeOk IS INP1
SecondAxisHomeOk IS INP2
Axis1DriveOk IS INP5
Axis2DriveOk IS INP6
EStopOk IS INP8
ToolTurretPosBit1 IS INP33
ToolTurretPosBit2 IS INP34
ToolTurretPosBit3 IS INP35
ToolTurretPosBit4 IS INP36
DriveOk IS INP37
LubeOk IS INP40
OUTPUT1 IS OUT1
OUTPUT2 IS OUT2
OUTPUT3 IS OUT3
Flood IS OUT4
WorkLight IS OUT5
LubePump IS OUT6
PartChute IS OUT7
NoFaultOut IS OUT8
SpinFWD IS OUT33
SpinREV IS OUT34
VFDResetOut_O IS OUT35
RotateToolTurret IS OUT36
TailStockInOut IS OUT37
OpenChuck IS OUT39
CloseChuck IS OUT40
X 12.6986 8000
EStopOk IS INP8
DriveOk IS INP37
LubeOk IS INP40
OUTPUT1 IS OUT1
OUTPUT2 IS OUT2
OUTPUT3 IS OUT3
Flood IS OUT4
WorkLight IS OUT5
LubePump IS OUT6
PartChute IS OUT7
NoFaultOut IS OUT8
SpinFWD IS OUT33
SpinREV IS OUT34
OpenChuck IS OUT39
CloseChuck IS OUT40
CNC12 v. 4.50 coordinates file
Axis Minus limit Plus limit
Z -7.0000 1.0000
X -4.0000 1.0000
Z -7.0000 1.0000
X -4.0000 1.0000
That's certainly odd but as Keith stated everything you need is in your report.
Thank You!!!!! I had ZRI(Z) on input 3 and ZRI(X) on input 4. the only option is "ZRIHomingall". How do I handle this in the new version?
ShawnM, I agree everything is probably in the report but if don't know where to get the information in the report you could just being going down a rabbit hole.
start configuring the new version of CNC12 , post a fresh report.zip from that version and we will help you along the way. forward!
