Acer e-Mill Anilam to AllIn1DC conversion build
Skunk
CNC Control System Serial Number: 0008dc111213-1223222881
Re: Acer e-Mill Anilam to AllIn1DC conversion build
Post by Skunk »
Well the message at startup is gone! Guess I have a working system....well other than the spindle. Who needs a spinning spindle on a CNC mill anyway huh'?
Now to go figure this part out.. Happy Easter
Skunk
Post by Skunk »
Eureka!
Faulty contactor.
Moved wires from L1/T1 to unused L3/T3.
We have a working spindle now.
Skunk
Post by Skunk »
It's back?
Machine setup
Not completed.
Machine is not ready
to run.
Contact your dealer.
report_0008DC111213-1223222881_2023-04-11_08-21-25.zip
(4.93 MiB) Downloaded 6 times
S-K Machine
CNC Control System Serial Number: A901038
Post by S-K Machine »
Are you following the installation manual?
You should and not be jumping all over the place.
Page 72
6.13 PERFORMING A SYSTEM TEST
In some versions of CNC12 software, when finished, the main menu will display a message saying “Machine Setup Not
Completed. Machine Is Not Ready To Run. Contact Your Dealer” as shown below.
At this point you will need to run the System Test to clear this message. Documentation on how to perform a system test is
located here. (http://centroidcnc.com/usersupport/supp ... emtest.pdf )
Skunk
Post by Skunk »
I do not disagree with you at all. My issue is that the test was performed and the message cleared, but then it returned.
Upon attempting to run the tests again I get an error about a missing parameter. When investigating that parameter error I find that the test actually just failed for reason "X or Y". Be nice if they results just said "Failed" and why instead of saying missing parameter. Bit misleading to me.
Why the test failed is in the test log file.
Skunk
Post by Skunk »
I am starting to get frustrated 3 times today I started with page one. worked through to page 71. Keep getting stuck with 907 X axis travel exceeded. I am on step 5 of 6.11 Software travel limits in the instructions.
Skunk
Post by Skunk »
Figured a way around the error.
Skunk
Post by Skunk »
Now the system "Test"
After pressing Cycle Start
Outputs 306 Job Finished without doing a darn thing.
No errors no movement
Skunk
Post by Skunk »
Really? That is how you pass the test?
No interaction or acknowledgement on screen?
Finally I can make parts again?
