Acorn CNC12 v4.80 has been released. (8-12-22)
Re: XY Jogging now available. Test it out... V4.79 rev3 BETA Now available.
Then I have no Idea, made a couple of Beta installs, all with no problem.
If you have any problems, please post a fresh report.zip to give us the information to figure it out Thank you
Thanks. The spindle bench test is intended to be running without runtime graphics running. Just switch to the G-Code view and it works.Spartan117 wrote: ↑Sat Jul 02, 2022 9:47 am I can't say if it's because of the beta, because i haven't done that with the stable release yet, but:
the spindlebenchtest.cnc doesn't work as described in the manual.
After loading the spindlebenchtest.cnc and pressing cycle start, the screen blacks out and it states "Line #16" at the top of the screen.
See here:
From there, i can't do ANYTHING anymore. Stop, Start, nothing happens, the black-screen seems to block everything.
Without the spindlebenchtest.cnc started, CNC12 itself seems to work, can jog, can home, can start spindle and even throws the correct voltage at the 0-10V-header.
Hope this helps and it's not me again^^
Re: Who is up for some new Acorn CNC software testing? V4.79 rev3 Now available.
I've seen Windows defender block the VCP. open it and make exception for the VCP
@cnckeith
Thank you for your answer (and for all your videos and manuals
Maybe this can be mentioned in the manual?
I suppose, the spindlebenchtest will be used by beginners most of the time.
Beginners, that often don't know much about RTG and such stuff yet.
German-speaking, so please be patient with my english-skills
we have modified the spindle bench test so it will work with RTG, i'll post a v4.80 release candidate soon that will have this improvement.Spartan117 wrote: ↑Thu Jul 07, 2022 8:39 am @cnckeith
Thank you for your answer (and for all your videos and manuals)
also, make sure the CNCPC Windows is set to "Run as Administrator"
- CNC Control System Serial Number: 0943
Can the beta be extended past 15 days. I actually do other things. Thanks.
John
John
i'll be posting another build here shortly. beta should be good for 40 days.
you can also change the date on the cnc pc to buy time
