Acorn CNC12 v4.80 has been released. (8-12-22)
Re: XY Jogging now available. Test it out... V4.79 rev3 BETA Now available.
Then I have no Idea, made a couple of Beta installs, all with no problem.
If you have any problems, please post a fresh report.zip to give us the information to figure it out Thank you
Spartan117 wrote: Sat Jul 02, 2022 9:47 am I can't say if it's because of the beta, because i haven't done that with the stable release yet, but:
the spindlebenchtest.cnc doesn't work as described in the manual.
After loading the spindlebenchtest.cnc and pressing cycle start, the screen blacks out and it states "Line #16" at the top of the screen.
See here:
From there, i can't do ANYTHING anymore. Stop, Start, nothing happens, the black-screen seems to block everything.
Without the spindlebenchtest.cnc started, CNC12 itself seems to work, can jog, can home, can start spindle and even throws the correct voltage at the 0-10V-header.
Hope this helps and it's not me again^^
Thanks. The spindle bench test is intended to be running without runtime graphics running. Just switch to the G-Code view and it works.
Re: Who is up for some new Acorn CNC software testing? V4.79 rev3 Now available.
Filardo wrote: Thu Jul 07, 2022 12:00 am
Hello I tried to install this version but the virtual control panel on the right does not want to install
Bonjour j'ai essayé d'installer cette version mais le panneau de commande virtuelle de droite ne veux pas s'installe pas
I've seen Windows defender block the VCP. open it and make exception for the VCP
Spartan117
Post by Spartan117 »
@cnckeith
Thank you for your answer (and for all your videos and manuals ;-))
Maybe this can be mentioned in the manual?
I suppose, the spindlebenchtest will be used by beginners most of the time.
Beginners, that often don't know much about RTG and such stuff yet.
German-speaking, so please be patient with my english-skills :)
Spartan117 wrote: Thu Jul 07, 2022 8:39 am @cnckeith
we have modified the spindle bench test so it will work with RTG, i'll post a v4.80 release candidate soon that will have this improvement.
also, make sure the CNCPC Windows is set to "Run as Administrator"
n2xd
CNC Control System Serial Number: 0943
Post by n2xd »
Can the beta be extended past 15 days. I actually do other things. Thanks.
John
n2xd wrote: Mon Jul 18, 2022 2:21 pm Can the beta be extended past 15 days. I actually do other things. Thanks.
John
i'll be posting another build here shortly. beta should be good for 40 days.
you can also change the date on the cnc pc to buy time
n2xd
Post by n2xd »
