Plasma Version of CNC12 Wish list
Scary
Re: Plasma Version of CNC12 Wish list
Post by Scary »
Jasic/Unimig is extremely common here in Australia. Yes they are made in china but they seem to be quality machines, not like the Ebay junk. CEA are also another unit and it is made in Italy. I am happy to run a few test cuts on my table with a scope connected to the 10v divider and send you a report if it would be of any help. I am currently running Mach3 with fibre THC unit but learning Intercon on my lathe has completely converted me so now I want to upgrade the table and convert my mill :)
scope shots of the divided voltage output while cutting at the cut height would be great. toss them up full res on a google photo album and post the link here.
Scary
Post by Scary »
Not a problem, It may take me a day or two as I have the machine down for new slide rail bearings. Cheers
legacytorch
CNC Control System Serial Number: 985DAD489A3F-1215170079
Post by legacytorch »
I use a Thermal Dynamics/Victor/ESAB unit. As long as the acorn is ok with the 50:1 voltage divider should be good running my non certified junk. :lol:
mighty_mike015
CNC Control System Serial Number: 3125
Post by mighty_mike015 »
cnckeith wrote: Thu Feb 03, 2022 7:07 pm what other cutting machines do you have in mind?
I think PrimeWeld's Cut60 machine would be worth looking at. If my Hypertherm 45 ever goes out, I was going to look into this as a replacement.
https://primeweld.com/products/cut-60-2 ... sma-cutter
mighty_mike015 wrote: Wed Feb 09, 2022 1:41 pm
we have one, so far not good. will test some more but we put it on the shelf for now.
Lincoln Flex cut has been working now for two weeks so it will most likely be added to the approved list.
legacytorch wrote: Wed Feb 09, 2022 10:45 am I use a Thermal Dynamics/Victor/ESAB unit. As long as the acorn is ok with the 50:1 voltage divider should be good running my non certified junk. :lol:
i heard good things about this unit, would like to test one!
mighty_mike015
cnckeith wrote: Wed Feb 09, 2022 3:08 pm
Thanks Keith. Good to know. Have you expressed your concerns with PrimeWeld? From what I've seen they are very receptive to criticism/suggestions.
Last edited by mighty_mike015 on Wed Feb 09, 2022 3:38 pm, edited 1 time in total.
Plasma CNC Controller: Yes
mighty_mike015 wrote: Wed Feb 09, 2022 3:16 pm
Thanks Keith. Good to know. Have you expressed your concerns with PrimeWeld? From what I've seen they very receptive to criticism/suggestions.
We have been working with PrimeWeld. I do not know where they stand but have inquired.
mighty_mike015
Thanks Marty!
