Plasma Version of CNC12 Wish list
- CNC Control System Serial Number: None
Re: Plasma Version of CNC12 Wish list
Jasic/Unimig is extremely common here in Australia. Yes they are made in china but they seem to be quality machines, not like the Ebay junk. CEA are also another unit and it is made in Italy. I am happy to run a few test cuts on my table with a scope connected to the 10v divider and send you a report if it would be of any help. I am currently running Mach3 with fibre THC unit but learning Intercon on my lathe has completely converted me so now I want to upgrade the table and convert my mill
scope shots of the divided voltage output while cutting at the cut height would be great. toss them up full res on a google photo album and post the link here.
Not a problem, It may take me a day or two as I have the machine down for new slide rail bearings. Cheers
- CNC Control System Serial Number: 985DAD489A3F-1215170079
I use a Thermal Dynamics/Victor/ESAB unit. As long as the acorn is ok with the 50:1 voltage divider should be good running my non certified junk.
- CNC Control System Serial Number: 3125
I think PrimeWeld's Cut60 machine would be worth looking at. If my Hypertherm 45 ever goes out, I was going to look into this as a replacement.
https://primeweld.com/products/cut-60-2 ... sma-cutter
we have one, so far not good. will test some more but we put it on the shelf for now.mighty_mike015 wrote: ↑Wed Feb 09, 2022 1:41 pmI think PrimeWeld's Cut60 machine would be worth looking at. If my Hypertherm 45 ever goes out, I was going to look into this as a replacement.
Lincoln Flex cut has been working now for two weeks so it will most likely be added to the approved list.
i heard good things about this unit, would like to test one!legacytorch wrote: ↑Wed Feb 09, 2022 10:45 am I use a Thermal Dynamics/Victor/ESAB unit. As long as the acorn is ok with the 50:1 voltage divider should be good running my non certified junk.![]()
Thanks Keith. Good to know. Have you expressed your concerns with PrimeWeld? From what I've seen they are very receptive to criticism/suggestions.cnckeith wrote: ↑Wed Feb 09, 2022 3:08 pmwe have one, so far not good. will test some more but we put it on the shelf for now.mighty_mike015 wrote: ↑Wed Feb 09, 2022 1:41 pmI think PrimeWeld's Cut60 machine would be worth looking at. If my Hypertherm 45 ever goes out, I was going to look into this as a replacement.
Last edited by mighty_mike015 on Wed Feb 09, 2022 3:38 pm, edited 1 time in total.
- Plasma CNC Controller: Yes
We have been working with PrimeWeld. I do not know where they stand but have inquired.mighty_mike015 wrote: ↑Wed Feb 09, 2022 3:16 pmThanks Keith. Good to know. Have you expressed your concerns with PrimeWeld? From what I've seen they very receptive to criticism/suggestions.cnckeith wrote: ↑Wed Feb 09, 2022 3:08 pmwe have one, so far not good. will test some more but we put it on the shelf for now.mighty_mike015 wrote: ↑Wed Feb 09, 2022 1:41 pm
Thanks Marty!
