First test router retrofit using acorn and cnc12
Post your completed retrofits for the world to see.
Re: First test router retrofit using acorn and cnc12
wow! fantastic..looks like a million bucks!
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
+1 That is seriously nice work Noel
Hope this helps
Nigel
noel-nogal
CNC Control System Serial Number: (2669)
Post by noel-nogal »
connecting I/Os from Acorn and Ether1616 for operate multi spindle drill head, now is done.
noel-nogal
this is a test of a simple g code program that embedded macros for multi spindle drills under Mcode representing mfuncXX.mac
noel-nogal
here are the multi spindle drills running one by one or sets of two and three, they can be configured by just changing the Mxx number that represent every drill.
in every macro is determined the offset position for that drill from origin, followed by the G91 it position that drill where it needs to be.
so when the Mxx code is called in the program each drill search it's position. that is the best way i could find when using a cad/cam software like Vcarve.
i laso had to create a new post procesor to generate drill programs separate.
maybe some one has a better solution for this operations?
noel-nogal wrote: Tue Nov 16, 2021 1:44 pm acorn04 (2).jpg
nice and clean! thanks for posting.
noel-nogal
right on! production mode!!
noel-nogal
Mr. keith
i am trying to unlock the work cordinates system from #7 to #18 but they just do not unlock with the F2 key or the button, do you know how to do this, i need enter values for setting my multi spindle drills, i have 10 drills and i am using wcs from G55 to G59 assigning each drill offset on each wcs, but i need the extra ones to assign the other 5 drills.
best regards
Noel
noel-nogal wrote: Thu Dec 23, 2021 5:36 pm Mr. keith
best regards
Noel
Please post a fresh report.zip
