New Build: SYIL X4 CNC Mill, Clearpath SDSK, C86ACCP & Centroid Acorn
ballsop123
Re: New Build: SYIL X4 CNC Mill, Clearpath SDSK, C86ACCP & Centroid Acorn
Post by ballsop123 »
Here is an STL file you can run .... Test fit and send me the changes we need to add or make....
Holes in lower mount are .150 " thru and the Side Board holes are made for M2.5 tap drill size...
Let me know how you make out with this.
Brian
Bracket 1 First Run.zip
(298.75 KiB) Downloaded 281 times
LucidCnC
CNC Control System Serial Number: 0C1C5713AC80-0526203339
Post by LucidCnC »
I wasn't able to load your file to slice?
ballsop123
What other format will you system take ?
snortwheeze
CNC Control System Serial Number: 4230
Post by snortwheeze »
I just downloaded it today. It’ll be this weekend before I can take my acorn board out of service to mount this mount.
ballsop123
How did you make out with the bracket mounting ? Assume some changes may be needed ? Let me know if you can... Thanks Brian
Custom Creations
CNC Control System Serial Number: 0035FF9B30A3-0322214535
Post by Custom Creations »
ballsop123 wrote: Wed Aug 18, 2021 12:13 am Well ... Here is a bracket .... First kick at the can so to speak ...
Attached is a Jpeg screen capture ... Take a look and let me know what you think ....
I don't have all the pieces built yet on the CNC4PC board but the dimensions of the board and the hole locations are per the drawing sent to me...
If you like it or have suggestions let me know and I can tweak it some more.
Brian
I would suggest to at least make these 2 surfaces flat so it can lay on the printer bed.
ballsop123
Here is an updated STL file with the extended pads removed per you sketch sent to me...
Let me know how it worked out for you....
Bracket 1 Second Run.zip
(280.02 KiB) Downloaded 309 times
Custom Creations
I can at least confirm that the brace mounts to the Acorn. For the fitment of the ACCP? Well, I forgot I changed my order to the C86ACORN instead for my setup :/
ballsop123
I have the Acorn Board already ... I will buy one of the C86A boards and 3D print one for myself to check fitment ....
Stay tuned for the fitment report ...
beevo
Post by beevo »
Got a loose Acorn Board you could loan me to do this?
Beevo
Beevo (aka Bill VanOrden)
Tempe, AZ
