New Build: SYIL X4 CNC Mill, Clearpath SDSK, C86ACCP & Centroid Acorn
Re: New Build: SYIL X4 CNC Mill, Clearpath SDSK, C86ACCP & Centroid Acorn
Here is an STL file you can run .... Test fit and send me the changes we need to add or make....
Holes in lower mount are .150 " thru and the Side Board holes are made for M2.5 tap drill size...
Let me know how you make out with this.
Brian
Brian
- Bracket 1 First Run.zip
- (298.75 KiB) Downloaded 242 times
- CNC Control System Serial Number: 0C1C5713AC80-0526203339
I wasn't able to load your file to slice?
What other format will you system take ?
- CNC Control System Serial Number: 4230
I just downloaded it today. It’ll be this weekend before I can take my acorn board out of service to mount this mount.
How did you make out with the bracket mounting ? Assume some changes may be needed ? Let me know if you can... Thanks Brian
- CNC Control System Serial Number: 0035FF9B30A3-0322214535
I would suggest to at least make these 2 surfaces flat so it can lay on the printer bed.ballsop123 wrote: ↑Wed Aug 18, 2021 12:13 am Well ... Here is a bracket .... First kick at the can so to speak ...
Attached is a Jpeg screen capture ... Take a look and let me know what you think ....
I don't have all the pieces built yet on the CNC4PC board but the dimensions of the board and the hole locations are per the drawing sent to me...
If you like it or have suggestions let me know and I can tweak it some more.
Brian
Here is an updated STL file with the extended pads removed per you sketch sent to me...
Let me know how it worked out for you....
I can at least confirm that the brace mounts to the Acorn. For the fitment of the ACCP? Well, I forgot I changed my order to the C86ACORN instead for my setup :/
I have the Acorn Board already ... I will buy one of the C86A boards and 3D print one for myself to check fitment ....
Stay tuned for the fitment report ...
Got a loose Acorn Board you could loan me to do this?
Beevo
Beevo
Beevo (aka Bill VanOrden)
Tempe, AZ
Tempe, AZ
