Emco Pc turn 50
Gordon1234
Re: Emco Pc turn 50
Post by Gordon1234 »
No problems marty ;)
No relays not wired, because I d'ont know how wiring them. Wich one goes to DC+ and DC- ? IN goes to acorn input ?
Plasma CNC Controller: Yes
Re: Emco Pc turn 50
Just wire the turret sensors to the relay first to get them turning on and off first. Sensor output is the relay board input.
Gordon1234
Re: Emco Pc turn 50
Ok will try this today or tomorrow ;)
Re: Emco Pc turn 50
Gordon1234 wrote: Sun Dec 13, 2020 1:45 pm Ok will try this today or tomorrow ;)
You do have to supply +5VDC to the board for power.
Use the same power supply to power your relay board and your sensors.
The Sensor OUTPUT is your relay board input.
When you trip a sensor, the relay should activate
If it the relay is ACTIVATED and then DEACTIVATES when you trip the sensor, then move the jumper on the relay board from High to Low and try that.
It is the OUTPUT of the relay that will connect to Acorn input. The relay commons will go to your power supply COM.
Does that make sense?
Gordon1234
Re: Emco Pc turn 50
Ok, so 5V/com on DC+ and DC-, sensor output on input relay board, ok for jumper, and there is NC, COM and NO on the other side, so relay COM to power supply COM, and output NC or NO to acorn input. I'm good ?
Re: Emco Pc turn 50
Output NO to Acorn. You can change it if needed.
Just get the relays working first with the two optical sensors.
Gordon1234
Re: Emco Pc turn 50
Thank you, today was spindle setup for my milling machine (ac servo), tomorrow the lathe !
Gordon1234
Re: Emco Pc turn 50
Hello !
Some news today.
Wire done, no problems.
Input 3 green for tool 1 (tool sync) it's ok, but input 4 (tool position) never green (always red), but relay works fine with sensor for each tool. Maybe a parameter in wizard ? (tested with "tool counter" and "tool position bit 1")
Re: Emco Pc turn 50
Gordon1234 wrote: Sun Dec 20, 2020 7:39 am Hello !
Some news today.
You are looking at the diagnostic screen? Alt i to toggle.
Make sure your relay common goes to Acorn Power supply Com. And I assume you are using normally open, so it should go to Acorn input 4.
Please post a picture of your wiring.
Gordon1234
Re: Emco Pc turn 50
Yes with diagnostic scrren on alt i. Yes, NO output like you said.
Here is a picture of wiring, I use power source of acorn (24V ansd 5V)
