Feed rate override question
Mrcadcam
CNC Control System Serial Number: 0622050849
Post by Mrcadcam »
I'm new to centroid controls and I have a CNC11 DC system. I recently just powered it up and noticed that the feed rate override knob turns past 100% but the readout on the screen will not go beyond 100%. It will go less than 100% down to 2% but not over. Is this normal? Thanks for helping out a centroid newbie.
Re: Feed rate override question
Parameter 39 controls the feedrate override limit. It can be set up to 200 to allow 200% of the programmed feedrate.
Mrcadcam
Post by Mrcadcam »
Thanks I checked it and it's set on 100 unfortunately I can't change it because it is password protected and I did not receive a password on purchase and cannot query the previous owner for it.....so I'm kind of stuck. Is there a way around the password?
Mrcadcam
Post by Mrcadcam »
Never mind I looked in the forum and saw that 137 is used for a password so I tried it and it let me in. Then I was able to change parameter 39 to 200
