all in one dc does not pass bench test <resolved>
- CNC Control System Serial Number: a900749
just powered up allinonedc I received a couple weeks ago using supplied power supply for bench test per manual. +12V analog led and -12v are off. A check with voltmeter on power supply shows proper +12V and -12V output. No other accessories have been connected yet. Blinking '4.' displaying correctly. I don't believe this passes bench test. Please advise. warnerr@recabaren.com
Re: all in one dc does not pass bench test
Hello.
Be sure to follow Marty's excellent all in one DC installation video series here is the link. viewtopic.php?f=20&t=2421
Warner, please post pictures of your benchtest setup.warnerr wrote: ↑Fri Jun 14, 2019 10:20 pm just powered up allinonedc I received a couple weeks ago using supplied power supply for bench test per manual. +12V analog led and -12v are off. A check with voltmeter on power supply shows proper +12V and -12V output. No other accessories have been connected yet. Blinking '4.' displaying correctly. I don't believe this passes bench test. Please advise. warnerr@recabaren.com
All in One DC are tested at the factory before shipping.
Need to "see" what you are working with.
I assume your power supply came prewired with the logic power cable and you have not disconnected or reconnected anything on the power supply?
two photos- this is the power up test. NOTHING has yet bern connected.
Thanks for the pictures.
Please make sure you use a 3 wire with ground power cable.
Check the +12v(yellow) and -12v(blue) using the black wire (common) as reference at the logic connector that plugs into All in One DC.
If you find you read somewhere very near to +12vdc and -12vdc respectively, give Centroid support a call first thing on Monday morning. Be sure to have the unlock sheet in front of you and be in front of your AIO DC benchtest setup.
ok- will do. volts are good on power supply. only ‘fault’ i have is for quick bench test using lampcord- that will not be used in real setup!
Factory power supply cord blue wire did not have continuity. Extracted wire and soldered both ends- cant beat old school! All lights report SUCCESS! Thank you to support!
Glad you got it going.
I mentioned you check at the connector no?
Plow forward!
