all in one dc does not pass bench test <resolved>
warnerr
CNC Control System Serial Number: a900749
Post by warnerr »
just powered up allinonedc I received a couple weeks ago using supplied power supply for bench test per manual. +12V analog led and -12v are off. A check with voltmeter on power supply shows proper +12V and -12V output. No other accessories have been connected yet. Blinking '4.' displaying correctly. I don't believe this passes bench test. Please advise. warnerr@recabaren.com
Re: all in one dc does not pass bench test
Hello.
Be sure to follow Marty's excellent all in one DC installation video series here is the link. viewtopic.php?f=20&t=2421
warnerr wrote: Fri Jun 14, 2019 10:20 pm just powered up allinonedc I received a couple weeks ago using supplied power supply for bench test per manual. +12V analog led and -12v are off. A check with voltmeter on power supply shows proper +12V and -12V output. No other accessories have been connected yet. Blinking '4.' displaying correctly. I don't believe this passes bench test. Please advise. warnerr@recabaren.com
Warner, please post pictures of your benchtest setup.
All in One DC are tested at the factory before shipping.
Need to "see" what you are working with.
I assume your power supply came prewired with the logic power cable and you have not disconnected or reconnected anything on the power supply?
warnerr
Post by warnerr »
two photos- this is the power up test. NOTHING has yet bern connected.
warnerr wrote: Sat Jun 15, 2019 10:49 am two photos- this is the power up test. NOTHING has yet bern connected.
Thanks for the pictures.
Please make sure you use a 3 wire with ground power cable.
Check the +12v(yellow) and -12v(blue) using the black wire (common) as reference at the logic connector that plugs into All in One DC.
If you find you read somewhere very near to +12vdc and -12vdc respectively, give Centroid support a call first thing on Monday morning. Be sure to have the unlock sheet in front of you and be in front of your AIO DC benchtest setup.
warnerr
Post by warnerr »
ok- will do. volts are good on power supply. only ‘fault’ i have is for quick bench test using lampcord- that will not be used in real setup!
warnerr
Post by warnerr »
Factory power supply cord blue wire did not have continuity. Extracted wire and soldered both ends- cant beat old school! All lights report SUCCESS! Thank you to support!
warnerr wrote: Mon Jun 17, 2019 1:14 pm Factory power supply cord blue wire did not have continuity. Extracted wire and soldered both ends- cant beat old school! All lights report SUCCESS! Thank you to support!
Glad you got it going.
I mentioned you check at the connector no?
Plow forward!
