DC3IO errors. A little help please
frijoli
Post by frijoli »
  • on the DC3IOb board, the segmented LED shows a 1(power out of specification); Checked the voltages and they are in specification. Power from the ATX seems correct, and the gray wire shows 4.8vdc. All the LEDS appear top be lighted up correctly.
  • 404 Spindle fault; Still trying to understand what this is and/or where to find the data
  • 9007 axis 3 communication error; I can't find data for this
Thanks in advance!
Clay
near Winston-Salem, NC
frijoli
Re: DC3IO errors. A little help please
Post by frijoli »
Well, it's going downhill fast...
New error messages
428
102
103
452
report.zip
(4.04 MiB) Downloaded 129 times
report.txt
(81.62 KiB) Downloaded 137 times
Clay
eng199
Post by eng199 »
Just to verify... the 1 is flashing with decimal point lit (an error condition)? This error is entirely a result of what the supply reports on the grey wire. Was error code 1 still flashing while you took voltage readings? Unless something very unusual is happening, the supply is probably intermittent and happened to give 4.8V at the instant you measured it.
Errors 102, 103, and 452 indicate some fundamental problems. They should be the focus to start with. They could be the result of power glitches resetting the DC3IOB. Do you have another ATX supply available to test?
Have you changed anything???
Fix things one at a time.
Spindle drive fault is just that. If there is a VFD, make sure it is powered up. If the VFD is not on line or faulted, you will get the fault. Make sure the fault signal from the VFD is wired properly.
Have you tried to look at the diagnostic screen Alt i?
Should be similar to Acorn, so you should be familiar with things....
frijoli
Post by frijoli »
eng199 wrote: Tue Apr 09, 2019 8:12 am Just to verify... the 1 is flashing with decimal point lit (an error condition)?
Not flashing. no decimal point. I didn't realize it needed that to be considered a fault. The docs are a little obscure in some areas.
eng199 wrote: Tue Apr 09, 2019 8:12 am Errors 102, 103, and 452 indicate some fundamental problems. They should be the focus to start with. They could be the result of power glitches resetting the DC3IOB. Do you have another ATX supply available to test?
I don't have another. I am going to swap the Cat5 cable and move some wiring around. The previous owner was obviously a machinist and not an electrician. lol
For my understanding are the above errors related to the PC communicating with the MPU11, or the MPU11 not communicating with the DC3IO, or both?
Clay
frijoli
Post by frijoli »
martyscncgarage wrote: Tue Apr 09, 2019 9:39 am Have you changed anything???
Nope, powered it down, and back up to start testing and got new errors. Only thing I changed was disconnecting the USB wireless mouse. I plugged it back in but messages were still there, when I rebooted.
martyscncgarage wrote: Tue Apr 09, 2019 9:39 amFix things one at a time.
Understood!
martyscncgarage wrote: Tue Apr 09, 2019 9:39 amSpindle drive fault is just that. If there is a VFD, make sure it is powered up. If the VFD is not on line or faulted, you will get the fault. Make sure the fault signal from the VFD is wired properly.
No VFD yet. I have to track down where the fault input is so I can trace what turns it on.
martyscncgarage wrote: Tue Apr 09, 2019 9:39 amHave you tried to look at the diagnostic screen Alt i?
Briefly to check the limit switches. I'll dig deeper today.
martyscncgarage wrote: Tue Apr 09, 2019 9:39 amShould be similar to Acorn, so you should be familiar with things....
Yeah, but I ain't that smart, lol
Clay
eng199
Post by eng199 »
frijoli wrote: Tue Apr 09, 2019 11:25 am
Since you don't have a power supply error, checking the PC to MPU11 communication is the way to go.
Cable, cable routing, firewall settings, ping test, etc. Did Windows apply an update when you rebooted?
frijoli
Post by frijoli »
eng199 wrote: Tue Apr 09, 2019 12:12 pm Since you don't have a power supply error, checking the PC to MPU11 communication is the way to go.
Pretty sure it's linux based.?. Certainly not connected to the Web anywhere, so no update I am aware of.
Clay
eng199
Post by eng199 »
Well, that's a good way to rule out Windows update. It does say Linux in the report.
frijoli
Post by frijoli »
Changed the com cable, and everything booted back the way it was originally. My gut says that wasn't the issue but it's okay for now.
I still have an error 428 to check the MPG cable. There is no MPG. What parameter turns this off? 19 is set to zero.
Clay
