9115 usb input setup fault
jasonborg
CNC Control System Serial Number: 3484E4275360-0702248379
Re: 9115 usb input setup fault
Post by jasonborg »
Yes I have com3 on the bob.
Now from that time we almost changed again and went through all the wiring maybe it was something coming from our side but found nothing and the problem still there.
It is funny and frustrating at the same time that centroid don't try and fix these kind of issues.i assume that it is something going on with the BOB.
Anyone from centroid is keen to help pls?
jasonborg wrote: Thu Jul 03, 2025 1:18 am Yes I have com3 on the bob.
Did you contact the service by mail as suggested?
jasonborg
Post by jasonborg »
i tried to send an e mail but from what i see you can only ask for tech support if you pay
and to be honest i dont feel i have to pay for tech support of this nature.it not about money cause if i know that i pay and solve the issue im fine to pay
my issue i that i choose the centroid this time over the linux as wanted to make the process faster but looks like i was wrong.when i donr linux retrofits i never had this kind of issues.
so that is why i wish that someone from centroid can jump in with a hand
centroid467
Post by centroid467 »
Hello, sorry for the delay.
We've managed to reproduce it internally and are actively working on fixing this issue and several other fixes and improvements for USBBOB.
jasonborg
Post by jasonborg »
Hi
Ok that sounds much better.thanks for the input.
Now any clues on target dates pls when this should be ready?
centroid467
Hello,
This fix is target to be included in CNC12 version 5.40.0. The software upgrade is currently in the testing process so I do not have a definite date for when it will be available.
a public beta v5.39.x will be available soon.
jasonborg
Post by jasonborg »
When are we going to have this fix pls as we need the machine to work and that was the reason we converted to centroid.to make it work not to leave it maybe one day we have this fix?
Any ideas ???
jasonborg wrote: Sat Jul 19, 2025 3:44 pm When are we going to have this fix pls as we need the machine to work and that was the reason we converted to centroid.to make it work not to leave it maybe one day we have this fix?
Any ideas ???
Use without the BOB instead of waiting for an update if you urgently need to make parts...
jasonborg
Post by jasonborg »
we are still stucked and we have a useless machine cause centroid decide to sell the BOB usb without proper testing.
its been so long that we are waiting for this fix and still we got nothing.
if that was with a linux cnc that would have been solved long time ago.
and no we cannot use it without the bob as the machine was wired that way and to rewire it its time consuming.
i would have assumed that centroid would have sorted this after this long time and trying to go around circles.
thanks centroid this will be the first and the last centroid install period
jason
