Posts: 3664 Joined: Thu Sep 23, 2021 3:49 pm
Post
by suntravel » Thu May 01, 2025 11:14 am
midy
Posts: 296 Joined: Wed Oct 11, 2017 12:20 pm
Post
by midy » Fri May 02, 2025 5:43 am
So, ive got to the stage where ive installed nppexec but nothing happens when i push F6? Even if i go into the plugins, the options shown on the Npp dropdown are limited to just the top section, the export and copy section?
Posts: 3543 Joined: Tue Mar 22, 2016 10:03 am
CNC Control System Serial Number: 100505 100327 102696 103432 7804732B977B-0624192192
Post
by tblough » Fri May 02, 2025 7:03 am
Did you follow the steps on page 4 of the Centroid Tuner App to configure Notepad++?
midy
Post
by midy » Fri May 02, 2025 7:33 am
Yes I did. I thought the tuner app did it automatically?
midy
Post
by midy » Fri May 02, 2025 9:27 am
Not sure on the instructions at step 3, does that read/mean if i have acorn that i skip to step 12?
Post
by tblough » Fri May 02, 2025 9:36 am
From the pdf Uwe posted earlier:
"3.) Follow the steps on the next page to run the PC Tuner App to configure files for Notepad++ or configure the files manually”
Follow the last paragraph on pg. 4 if you want to the tuner app to configure it for you, or follow the instructions starting on pg. 6 if you want to do it manually.
midy
Post
by midy » Fri May 02, 2025 9:54 am
Thanks Tom, im taklking about page 8 has this statement:
3.) For Acorn/AcornSix/Hickory systems or if you do not plan on compiling the PLC with Notepad++,
then skip to Step 12.
Does that mean if you have acorn you skip to step 12? Thats how it seems to read to me?
Post
by tblough » Fri May 02, 2025 11:24 am
You would be better off with the automatic configuration using the tuner instead of trying to do a manual install.
CentroidFrog
Tech Support
Posts: 141 Joined: Wed Jan 29, 2025 9:39 am
Post
by CentroidFrog » Fri May 02, 2025 12:34 pm
midy wrote: ↑ Fri May 02, 2025 9:54 am
If you want to compile the PLC using Notepad++ you'll want to continue to step 4, not skip to step 12.
midy
Post
by midy » Fri May 02, 2025 1:11 pm
ok thanks. Ill keep trying
