lathe spindle question
Re: lathe spindle question
Setup NP++ according to:
https://www.centroidcnc.com/dealersuppo ... ds/294.pdf
Hit F6 and be happy :)
midy
Post by midy »
So, ive got to the stage where ive installed nppexec but nothing happens when i push F6? Even if i go into the plugins, the options shown on the Npp dropdown are limited to just the top section, the export and copy section?
Did you follow the steps on page 4 of the Centroid Tuner App to configure Notepad++?
midy
Post by midy »
Yes I did. I thought the tuner app did it automatically?
midy
Post by midy »
Not sure on the instructions at step 3, does that read/mean if i have acorn that i skip to step 12?
From the pdf Uwe posted earlier:
"3.) Follow the steps on the next page to run the PC Tuner App to configure files for Notepad++ or configure the files manually”
Follow the last paragraph on pg. 4 if you want to the tuner app to configure it for you, or follow the instructions starting on pg. 6 if you want to do it manually.
midy
Post by midy »
Thanks Tom, im taklking about page 8 has this statement:
3.) For Acorn/AcornSix/Hickory systems or if you do not plan on compiling the PLC with Notepad++,
then skip to Step 12.
Does that mean if you have acorn you skip to step 12? Thats how it seems to read to me?
You would be better off with the automatic configuration using the tuner instead of trying to do a manual install.
CentroidFrog
Tech Support
Post by CentroidFrog »
midy wrote: Fri May 02, 2025 9:54 am Does that mean if you have acorn you skip to step 12? Thats how it seems to read to me?
If you want to compile the PLC using Notepad++ you'll want to continue to step 4, not skip to step 12.
midy
Post by midy »
ok thanks. Ill keep trying
