Foot Pedal to activate Rotary axis (C) in Acorn 4
Philip Venter
CNC Control System Serial Number: ACORN 6 0008DC111213-0605230114
ACORN 4 582BOAEOF3DE-0508237211
ACORN 4 2OD7787D28E8-0920226549
ACORN 4 247625F4F797-0330225837
Post by Philip Venter »
HI Team.
I want to rotate the C axis (rotary) on my acorn 4 custom machine by using a foot pedal.
the idea is to wire the signal wire into the input channel and once stepped on/ activated the C axis will rotate.
The issue is I don't have this option in the dropdown menu where I need to assign this functionality to the input signal.
Is there a way we can do this?
Looking forward to your response.
Regards
Re: Foot Pedal to activate Rotary axis (C) in Acorn 4
yes with a custom macro/plc and you can do stuff like this.
