Acorn Six has three encoder inputs. Will they work with my current magnetic scales? Precision Matthews MagAct 200.
With three encoder inputs used, What about the spindle encoder ? Plan is to set up for mill/turn machine.
Acorn Six encoder / Mag Scales
- CNC Control System Serial Number: 74E182A80DDE-0312191753
A job worth doing “right", is!
Re: Acorn Six encoder / Mag Scales
If you want to use 3 scales and spindle encoder, you need the encoder expansion board.
If your scales are compatible depends on if they have RS422 output, TTL may work with a line driver converting TTL to RS422
Thanks Uwe, I will check if RS422 protocol
RS422
Pin 1 2 3 4 5 6 7 8 9
Signal + Z - Z VCC Shield GND + A - A - B + B
Color Grey Brown Black Violet White Pink Red Green Yellow
Scales are of the RS422 type
