Hi i have an oak with CWP-4 wireless pendant and it doesn't connect to oak. I use it acorn and works just fine. It sees receiver reception. so here is a report.
when i select an axis and turn mpg, windows makes a sound but no pop up window or errors. and nothing under my properties has any driver issues.
cwp-4 not connecting to oak
- report_0008DC111213-1031221395_2023-04-16_19-48-57.zip
- (5.43 MiB) Downloaded 16 times
Re: cwp-4 not connecting to oak
The CWP-4 connects to the computer, through USB and Windows; not directly to the Oak or Acorn.
Have you tried using the computer from your Acorn control to run your Oak control; or vice versa? You can do that, simply by renaming your c:\cncm or c:\cnct directory, then installing the appropriate CNC12 version and restoring a Report.
yes im aware it connects to computer usb. i can see in the Hid under property management that its connecting and disconnecting for pc. I use this wireless on a diff lathe and a router and both work fine. Tired different usb ports and even bought an pci express to usb3.1 card to see if it was something from main board.cncsnw wrote: ↑Mon Apr 17, 2023 3:12 am The CWP-4 connects to the computer, through USB and Windows; not directly to the Oak or Acorn.
cant connect use computer from acorn on oak as the plc and stuff is way different.
hi i moved this thread into the beta test forum.
It was doing the same thing before i did the beta software upgrade.
post photo of the wireless LCD screen when CNC12 is running
