Job Timer
- CNC Control System Serial Number: 0035FF8A54E0-0610203404
Job Timer
Hi
So just curious as to why there is no "Time Remaining" displayed for jobs or even "Elapsed Time"
With the CAM software it displays total job time, including machine time, and travels ... So can that info not be passed onto CNC12 and have that time displayed somewhere easily read by the operator?
I just ask because when I post a job and CAM says 3:20:20 for example ... other than keeping time manually I have no idea at around what time that job will end ...
So maybe it could be incorporated at a later stage ??
Re: Job Timer
At the moment you can use M130 to start a external timer App
m130 "C:\MillDemo\FreeCountdownTimerPortable\FreeCountdownTimer.exe"
Re: Job Timer
Ah cool ...
Better than nothing I guess
Re: Job Timer
You can also use a simple batchfile as a timer .
- timer.zip
- (236 Bytes) Downloaded 8 times
Re: Job Timer
You can also "Graph" the job and the estimated time is shown when it's finish graphing. I have found it to be very close when running several hour 3D relief files.
Scott
Re: Job Timer
Yes, thats the time you need to dial in the countdown timer....
Re: Job Timer
There is a timer when you "Show GCODE" vs path
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
Re: Job Timer
This is what I do, once I graph the file I jot down the estimated time and when the job is running the g code screen shows a timer to reference it to.
I agree a countdown timer or estimated time to finish would be a great addition on one or both screens. My fiber laser shows the estimated time and actual time side by side on the screen. Certainly handy for the "longer" cut jobs.
Re: Job Timer
Am I missing something? I thought the elapsed run time of the job had been visible in the status window area, in the upper right of the screen, in every CNC7/CNC10/CNC11/CNC12 version since 1995.
Maybe you are mistaking the runtime graphics display as the only possible job-running display?
Re: Job Timer
Indeed I have 98% the RTG on
