907 Y-Axis Travel Exceeded
- CNC Control System Serial Number: (0035FF9127E0-1124204129)
I'm new to the CNC process and trying to run my first part. When I load a program and home my axis and try to run it I get a message that says "907 Y Axis Travel Exceeded". I've moved my axis to make sure none of my limit switches are tripped, reset the zero of my axis, and rehomed but still have this issue. From looking online it seems that this is likely a software limit I will have to change? I built my CNC a year ago but finally putting the finishing touches on it now so will need to find those soft limit settings again if that is the likely problem. Also, there are lots of troubleshooting and setup videos/manuals, is there a video any would recommend walking through running your first CNC part?
Re: 907 Y-Axis Travel Exceeded
That is because the program want to travel out of your machine range
If the part is not bigger than your travels, this is a problem where you set part 0
https://www.autodesk.com/products/fusio ... made-easy/
https://www.youtube.com/user/CentroidSupport/videos
