Can't run the job
Moderators: cnckeith, Joey
TAS99
Can't run the job
Post by TAS99 »
I have a new DYI plasma cutter and I've completed all the set-up procedures and I have cut a simple job but the one I'm referring to here has problems.
The job starts, the torch plunges rises and starts to cut a couple of inches and then for some reason the z lowers and trips the mechanical torch height switch. I get a message about a torch collision so I raise the Z axis to clear it hit run and it goes a couple more inches until I get the same problem again and again.
I'll include the beginning part of the code if it's any help.
Any help would be greatly appreciated.
;Filename: Big Foot UpperOuitline Only.tap
;Post processor: Centroid Acorn Plasma THC.scpost
;Date: 01/02/2023
G20 ;Units: Inches
G90
M65
;Part: Big Foot
;Operation: Outside Offset, UPPER, T1: 18GA Steel
G0 X7.882 Y18.3899
M61
G2 X8.3864 Y18.1888 I0.1517 J-0.3528
G3 X8.4431 Y18.2019 I0.0271 J0.0117
G1 X8.4287 Y18.4901
G1 X8.6176 Y18.0714
G3 X8.619 Y18.0686 I0.0269 J0.0122
G1 X8.7206 Y17.8962
G1 X8.7182 Y17.8946
G1 X8.6692 Y17.9148
G3 X8.6362 Y17.9076 I-0.0113 J-0.0273
G1 X8.5879 Y17.8551
G1 X8.5872 Y17.8544
G3 X8.5259 Y17.7771 I0.9569 J-0.8226
G3 X8.399 Y17.5895 I2.4859 J-1.8178
G3 X7.6369 Y15.8985 I6.1793 J-3.802
G3 X7.2101 Y13.5805 I9.9892 J-3.0376
G1 X7.187 Y13.2602
G3 X7.1869 Y13.2581 I0.0295 J-0.0021
Re: Can't run the job
We need more info and a current report. What plasma cutter do you have? Did you do the torch calibration? What’s happening is that after the THC delay the torch is diving to raise the voltage. Set the THC mode to “smart sense” and see what the voltage is compared to the profile manager.
