Morning gang. Trying to run the eStop test on page 39. I mean, it works as described, but from what I can tell the Out1 relay is not pulled in to engage 24Vac to the coil? Is that supposed to work or is there some other output config setup I need to complete? Or do I remove the 'all faults clear' from a previous step... Hmmmm?
Jeff
