When I purchased my used Ajax DM45 it came with a DP-4 and Mold Magic. I did not even think that the version of Mold Magic would be so old that it would load on a modern computer, cost me extra $$.
I have Mold Magic version 2.1 Rev.1. When I tried to load it on my Windows 7 PC it gives me an error when trying to run setup: "The version of this file is not compatible with the version of window you are running..."
I tried to load in compatibility mode but that didn't work.
Is there an update or upgrade for this software? Or is there a way to make this software work on Windows 7?
The unfortunate thing is that after purchasing an Ajax RT-150 and new TT-1 and DC1 I am running out of funds.
Mold Magic Version will not load on Win7
- CNC Control System Serial Number: 0823050980
Re: Mold Magic Version will not load on Win7
mold magic runs on XP only. some guys will buy an old running xp machine on ebay just to run it, but mostly they pick up a new cad/cam system to do that kind of work.
mold magic has been displaced by affordable 3D cad/cam systems such as vectric aspire and bob cad cam. (Aspire will accept a centroid .dig file directly.)
mold magic was created when these programs didn't exist or didn't have the 3D cutter compensation feature or were very expensive. It was a free program included with the dp-4 that could create roughing and finish passes from grid digitizing data.
now that affordable 3D cad cam systems are readily available and can do even more than mold magic, a decision was made not to continue the mold magic product.
if you like, i can send you the last version of mold magic (which does not require any kind of unlock or password to run) , the only limitation is that it will only run on a windows XP pc and it is un supported (except thru this free forum) but i'd suggest looking into Aspire or other similar programs to take advantage of the many new powerful features found in them and of course they run on windows 7 or 8 PC's.
Hi cnckeith,
This is twice your helping me out.......
The newest version would be nice to have. I was just trying to find my power supply to my old 32 bit XP machine to see if that would work with the software I have.
I do have BobCad/Cam v27 and BobArt and looked there but didn't see a .DIG extension. I also have Rhino5 and Turbocad on another computer but have not looked at that yet.
So if I can figure out how to get the point cloud into one of my programs then I should be ok with getting it into BobCad.
Please send me a private message with the newer version of Mold Magic, I guess that would be the best way for the software if it's not to big, or maybe I can open up a cloud location to get the files. If you have a better idea I'm open to it.
Thanks Again!!!
Thanks Again!!!
here is the beginning of a centroid radial digitizing file, this is the file created automatically by the centroid digitizing radial cycle on a cylinder head combustion chamber.
; containment radius = 1.8750
; contour step = 0.0200
; z patch length = -1.0000
; z step = 0.0200
; full or partial = 0
; start angle = 0.0000
; end angle = 360.0000
; clearance height = 0.0100
; replay pattern = 0
; filename = 20R
; multiple patch = 0
; replay feedrate = 65.0000
M25 G0 X0.0000 Y0.0000 Z0.0000 ; NO DATA
G1 F65.0000
X1.7116 Y0.0000 Z0.0000
X1.7138 Y0.0203 Z0.0000
X1.7149 Y0.0406 Z0.0000
X1.7166 Y0.0610 Z0.0000
X1.7182 Y0.0814 Z0.0000
X1.7191 Y0.1017 Z0.0000
X1.7199 Y0.1221 Z0.0000
X1.7205 Y0.1425 Z0.0000
X1.7204 Y0.1629 Z0.0000
X1.7200 Y0.1833 Z0.0000
X1.7201 Y0.2037 Z0.0000
X1.7193 Y0.2240 Z0.0000
X1.7183 Y0.2443 Z0.0000
X1.7184 Y0.2649 Z0.0000
X1.7167 Y0.2852 Z0.0000
X1.7153 Y0.3055 Z0.0000
X1.7137 Y0.3259 Z0.0000
X1.7116 Y0.3461 Z0.0000
X1.7099 Y0.3665 Z0.0000
X1.7078 Y0.3868 Z0.0000
X1.7046 Y0.4069 Z0.0000
etc...etc....
now i took this same file and ran it thru the DIG to CAD button in the Digitizing menu in the centroid software and here is what the beginning of it looks like.
1.711600 0.000000 0.000000
1.713800 0.020300 0.000000
1.714900 0.040600 0.000000
1.716600 0.061000 0.000000
1.718200 0.081400 0.000000
1.719100 0.101700 0.000000
1.719900 0.122100 0.000000
1.720500 0.142500 0.000000
1.720400 0.162900 0.000000
1.720000 0.183300 0.000000
1.720100 0.203700 0.000000
1.719300 0.224000 0.000000
1.718300 0.244300 0.000000
1.718400 0.264900 0.000000
1.716700 0.285200 0.000000
1.715300 0.305500 0.000000
1.713700 0.325900 0.000000
1.711600 0.346100 0.000000
1.709900 0.366500 0.000000
1.707800 0.386800 0.000000
1.704600 0.406900 0.000000
1.702400 0.427300 0.000000
1.699700 0.447500 0.000000
etc...etc...
i have attached the two files so you can see them., you can open them both with notepad.. or better yet notepad ++ (recommended)
- 20r.txt
- (469.3 KiB) Downloaded 232 times
and here is the .DIG original.. i had to rename the extension from .dig to .txt as phpBB was not allowing a .dig file to be attached.
if you want to play with the DIG to CAD button in the centroid software.. just rename it 20r.DIG and copy it to the ncfiles directory
- 20r_DIG.txt
- (423.21 KiB) Downloaded 247 times
