Oak with Yaskawa Sigma I jerking
carocad
Post by carocad »
I am converting an old wood router to OAK, but i am in a bit of a problem i cannot seam to find the solution for.
i have follow the installation manuals to configure the servos.
all 3 axis are on Yaskawa Sigma I drives with USAGED servos. old stuff but it is still turning.
my problem is that Y is not moving smooth at all, at any speed. faster is worst
X and Z i have nothing to complain about
i checked and triple checked wiring
I run PID and the graphs are all out of wack, so something is not right but i dont know how to fix it.
any help is much appreciated.
report_0008DC111213-0503211122_2022-05-05_11-19-44.zip
report
(3.78 MiB) Downloaded 40 times
z axis
z axis
y axis
y axis
x axis
x axis
carocad
Re: Oak with Yaskawa Sigma I jerking
Post by carocad »
I connected the drives to Sigma5 and all motors are moving smooth at different jog speeds.
jogging from centroid is okay for X and Z but Y is jolting at all speeds.
Do you really have ca. 0.16 motor revs per inch on the Y axis, vs. 1.0 and 5.0 revs/inch on X and Z?
What does "connected the drives to Sigma5" mean? I thought you were using Sigma I drives (e.g. SGDB- or SGDA- models). Sigma5 drives would be SGDV- models.
Have you tried running your original motors and drives in analog velocity mode instead of pulse-train position mode? Do you know what mode they ran in with the previous control?
carocad
Post by carocad »
yes, 1" on Y is 0.16 revs. this is a direct mount on a rack and pinion. i will get a reducer if needed.
Sigma5 should read SigmaWin+ (version5)
All drives are SGDB
all motors are now setup in 'Position control (pulse train reference)' as per OAK installation manual.
original machine setup was 'Speed control (analog reference)'
I have changed the Y to axis #3 on OAK with a new cable to the SGDB drive, problem still there.
I removed the motor and run PID from OAK at different speeds and the graph looks good, once the motor is in place then jerking starts (only on Y)
The mystery is that running the motor (installed in the CNC) from SigmaWin at any speed the machine moves very smooth.
direct mount rack doesn't work! need at least 3:1 reduction 5:1 is best.
Router and Plasma Machine Happy Zone
- Happy Zone Overall Turns Ratio for routers is 1.5 to 2.5 turns of the AXIS MOTOR yields 1" of table/gantry movement.
i would reinstall cnc12 and configure in position mode from the start. i've done several routers with the combo (oak yaskawa in position/precision mode) and it works well.
gear boxes are cheap and easy solution to put a router axis in the happy zone.
carocad
Post by carocad »
so in my case i will need a 10:1 or better to do 1.6 revs for 1" travel
can you please help me locate a good supplier for the gear box.
thank you.
last ones we bought were from LeadShine they are working well. for some reason they don't have them on their website.
automation has them as well. https://www.automationdirect.com/adc/sh ... sc&start=0
and very similar looking boxes can be found on alibaba and google. "cnc planetary gear box"
carocad
Post by carocad »
glad to report the 10:1 reducer is working VERY WELL.
thank you
carocad wrote: Wed Jun 15, 2022 5:00 pm glad to report the 10:1 reducer is working VERY WELL.
thank you
thanks for reporting back. post some photos would love to the machine.
