KP3 cable and wiring
- CNC Control System Serial Number: Acorn E415F6F6BFF1/0503203220 Colchester Lathe
and a Deckel FP1 with Acorn, both with WMPG - DC3IOB: No
Hello all,
today I receive my brand new KP3 and I cut the original cable to solder a small plug for the connecting box. I do the complete wiring and nothing works.
I this possible that the cable change the color of the wriing after the heat shrink tube?
Hope I destroy not my KP3.
Thanks in advance for your reply.
Best regards
Mathias
Best regards
Mathias
Re: KP3 cable and wiring
please post a fresh report.zip file so we can see your settings.
- Hickory CNC Controller: Yes
Yes. The extensions are added to collect the shield and get the colors to Centroid standard.
The molded barrel jack cord colors may change.
tip = detect
ring = probe input
barrel/shield = GND
use ohm meter/continuity tester to figure out which wire is connected to which contact on the barrel jack.
many thanks for the reply!
I will check it and try it again.
I ther any electronic inside of the probe and with critical parts after connecting to wrong terminals?
Please see attached report.
Kind regards
Mathias
KP3 is simple and robust, it should be fine.
Hello all,
everything is okay and it works nice.
One question, can you advice me the speed for the fast and slow feedrate for a KP3 for the feedrate?
Can I probe parts with the 4th axes?
Thanks a lot!
Thanks a lot!
fyi... KP-3 refit program.Mathes wrote: ↑Sat Feb 26, 2022 6:23 am Hello all,
One question, can you advice me the speed for the fast and slow feedrate for a KP3 for the feedrate? <depends on your goals..faster = less accurate. try 15 and 3 for starters which is typical for a milling machine or lathe.>
Can I probe parts with the 4th axes? < what do you have in mind?>
Thanks a lot!
https://www.centroidcnc.com/centroid_di ... ogram.html
Hello,
thanks for your advice!
Perfect support form you!
My probe with serial no 1231 is the new version, and need no refit.
Any advice from the feetrates for the digitizing an useing the 4th axes?
Mathias
Mathias
Hello,
I have done so e tests, and I have some issues with the KP-3.
During a digit process the controller stop after 6-8 proping moves and stop without any displayed errors.
After pressing any key of the keyboard the process start and stop again.
Any idea what's happened?
Thanks is advance
Mathias
Thanks is advance
Mathias
