Spindle Encoder Differential Error
viscoelastic
CNC Control System Serial Number: A901056
Post by viscoelastic »
First of this machine is a Bridgeport Explorer X26. The spindle encoder had 3 wires. My guess on colors was Red + Blk - Wht "A" signal. Once wired and enabled in the parameters, I received an encoder differential error. One, did I wire it correctly, two what did I goof up on?
Thanks!!
Re: Spindle Encoder Differential Error
If it only has three wires, it is not a suitable encoder.
You need a "quadrature", "differential" encoder: one with both A and B channels, and with two complementary wires per channel.
If you plan to do rigid tapping with it, you also need an index pulse (Z channel), also differential.
That makes eight wires, as shown on most any Centroid system schematic.
viscoelastic
cncsnw wrote: Fri Jan 14, 2022 12:15 am You need a "quadrature"
Thanks, That makes sense.
