Preview CNC12
Preview CNC12
Hi is it possible to view the CNC12 software if I don't have an Acorn board?
(I'm trying to get a feel for layout etc before making a purchase)
Thanks in advance,
David
Thanks in advance,
David
Re: Preview CNC12
I think I found my answer..... nope.
Re: Preview CNC12
Yes, somewhat. If you download the CNC12 version for Oak and AllIn1DC, you can install a demo version of CNC12. It does not have the Acorn Wizard, but the software snd VCP is exactly the same.
Re: Preview CNC12
Oh ok, that’s helpful thank you!
Re: Preview CNC12
So I installed CNC12 from the Oak page but for some reason the display is not correct even though the resolution is set to the recommended 1920x1080. I have no idea how to fix this as there's way to change the window position.
Re: Preview CNC12
It is normal, on a wide-format monitor, that CNC12 does not occupy the whole screen. There will be blank space to the right. In most Acorn installations, the VCP occupies that space.
Re: Preview CNC12
Does this look as it should?
Re: Preview CNC12
That is correct. CNC12 runs as a full-screen program and not as a normal window.
Under the CNCM directory, there should be a folder named Manual. Inside is a pdf version of the latest manual for CNC12. As mentioned earlier, it won't cover the Acorn Wizard but should help you get started.
Re: Preview CNC12
Thank you!
