Clean out Question
lavrgs
Clean out Question
Post by lavrgs »
I'm new to Intercon and am trying to understand it a bit better.
I created geometry
cw-x-arc.cnc
(1.47 KiB) Downloaded 86 times
as a Path. Now I want to remove the material inside. What is the approach I should take?
Re: Clean out Question
post a fresh report.zip and the Intercon program (.icn) that you are using.
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
As well as providing what Keith requested, you might like to review the Cleanout Canned Cycle noting the first move must be linear. You can then enter Arcs or Linear moves to plot your irregular shape to machine.
Hope this helps
Nigel
lavrgs
Post by lavrgs »
cnckeith wrote: Fri May 21, 2021 8:45 am post a fresh report.zip and the Intercon program (.icn) that you are using.
I will look into the Clean Out command - Can the existing code be embedded?
EDIT - I added a second intercon file after I did the clean out first. It's not really CLEAN - meaning there's a lot of monkey motion...The G Code probably could be cleaned up but I would have to spend some time learning
cw-roller2-xx.icn
intercon file
(7.04 KiB) Downloaded 77 times
cw-roller2-clean.icn
(7.24 KiB) Downloaded 90 times
report_402E71CADC40-0323214550_2021-05-21_08-52-45.zip
(637.35 KiB) Downloaded 87 times
lavrgs
Post by lavrgs »
After playing around it seems that using the cleanout before doing a rough/final on the profile might be best. Thanks Nigelo.
I wasn't able to find a way to move the original code into the Clean Out boundary.
The "monkey motion" was improved by making the boundary a closed loop - I had extended the final line to go beyond intersecting.
cnc_smith
Post by cnc_smith »
lavrgs:
In your Intercon program you are turning cutter comp before the clean-out cycle. The clean-out cycle automatic compensates for the diameter of the cutter. Remove the Comp Right line. If you changed the size of the cutter diameter you need to re-post the Intercon file. I changed your Intercon file line 18 back to X-.400 Y.400 the same as the start point it graphs correctly that way.
Dana
lavrgs
Post by lavrgs »
I will change per your recommendation and see if it comes out as expected- Thanks
