Outputs 5-8 don't fire from Virtual Control Panel <resolved>
wdannhardt
CNC Control System Serial Number: F045DA78ED76-1212181423
Post by wdannhardt »
Greetings fellow Acorn users, and thanks to all who provide feedback on this forum. I've got a problem with my outputs that I can't figure out.
I can get outputs 2-4 to fire from CNC 12. For example, if I set output 2 = coolant pump, then press the coolant icon the relay 2 opens fires. Same for outputs 3-4. If I set output 5 to coolant pump, the relay do not fire. Something is not configured correctly for relays 5-8. It's not specific to coolant, same problem for any function I assign.
If I use the ALT-I screen to view the I/O directly, I can manually fire relays 1-8 using cntrl-alt-f. So this tells me they are working. Although my output status indicators have three states.
1 Red circle (off)
2 Red circle with line under it (what does this mean)
3 Green circle (on)
When I press cntrl-alt-f the indicator cycles between the three states. My Centroid documentation does not describe this. Any ideas what is going on? I upgraded to the newest version of CNC12, but have the same issue.
Walt
Setup:
-2 axis lathe conversion from 12" Chinese 12x36
-Acorn Rev 4 (14455)
-CNC12 Lathe Version 4.6.2
-DYN4 servo's w/ 750w motors -Report attached
Re: Outputs 5-8 don't fire from Virtual Control Panel
PLC diagnostic screen documentation is here.
https://www.centroidcnc.com/centroid_di ... screen.pdf
on this page with all other Acorn documentation.
viewtopic.php?f=60&t=3397
anytime an output is not working 99.9% of the time the user has left the Output disabled in the PLC diagnostic screen.
is the control on the bench or install on the machine?
PLC program says:
             SV_FORCE_ON_OUT1_16_BITS    = SV_MACHINE_PARAMETER_921,
             SV_FORCE_OFF_OUT1_16_BITS   = SV_MACHINE_PARAMETER_926,
Report says:
 P921 =     0.00000  - Reserved for PLC
 P922 =     0.00000  - Reserved for PLC
 P923 =     0.00000  - Reserved for PLC
 P924 =     0.00000  - Reserved for PLC
 P925 =     0.00000  - Reserved for PLC
 P926 =     0.00000  - Reserved for PLC
So there does not appear to be a problem with forcing the outputs.
wdannhardt
Very strange, now its working fine. I went back and removed the output assignment (using the wizard) then re-added them. I also manually inverted 5-8, then manually un-inverted them in the diagnostic screen. This also involved a couple of power cycles and software re-starts. Works now.
Thanks guys.
Walt
