All In One bench test
Beagle Beagle
CNC Control System Serial Number: A900779
Post by Beagle Beagle »
Got a small problem. I'm doing the spindle voltage part of the bench test. When I hit alt-S for S500 I get a reading of 3.35 DCV. When I input it and continue I get an error message Invalid voltage. I checked and the max spindle speed is set at 3000rpm. What am I doing wrong here. Thanks Bob L
Bridgeport V2XT, All In One DC #A900779. Using existing SEM motors 112 Volt. Spindle to be controlled by Lenze AC Tech VFD mod #ESV222N02YXB. Machine is being run on 208 3Phase power.
Re: All In One bench test
Is your spindle connected to the Acorn at this point?
Beagle Beagle
Tom, I have an All In One. The spindle encoder is attached to the board but I have not run any wires to the VFD. Bob
Beagle Beagle wrote: Tue Feb 23, 2021 12:15 pm Got a small problem. I'm doing the spindle voltage part of the bench test. When I hit alt-S for S500 I get a reading of 3.35 DCV. When I input it and continue I get an error message Invalid voltage. I checked and the max spindle speed is set at 3000rpm. What am I doing wrong here. Thanks Bob L
Are you using a quality Voltmeter? Picture of your setup?
You haven't changed the max RPM from 3000 have you?
Beagle Beagle
Marty, As I stated. The max RPM is set to 3000. I'm using a Fluke 27. One of the best you could buy at one time.
Wired and in the cabinet does not qualify for a "bench test" ;)
Are you connecting your voltmeter DIRECTLY to the analog out connector with no other wires connected (like to a VFD)
AcornJosh
Post by AcornJosh »
Are you sure you have it set to 0-10 and not -10 to +10?
Edit to add:
Thought over this and -10 to 10 wouldn't make sense either but you should check the dip switches anyway.
Leave the spindle bench test. In MDI, type M3 S0. what voltages do you get? Try M3 S3000 and M3 S1500. What voltages do you get?
Here is my AIO DC Bench test video. At about 31:00 I show the leads connected to All in One DC Spindle analog output:
Beagle Beagle
That is exactly what I have and I will repeat my self. I have no wires to the VFD. And yes I've read the instructions and I've watched the video. This is not going to solve this problem. Go up and read my post first! Josh, the white screen that says this machine is not ready for operation won't let me into MDI or at least I tried and failed. Bob
We're trying to help and we start with the most overlooked. The basics
