spindle reverse button issues
I just updated my lathe to the newest cnc12. didnt go very smoothly but i was able to get everything to work. only issue im having is on the vcp the spindle reverse button acts like a momentary switch. my mill and the lathe before updating if you hit the reverse direction button it would run that way. now i have to hold it in. any ideas? i can post a video if im not being clear.
Jeremy
Pittsburgh, PA
Pittsburgh, PA
Re: spindle reverse button issues
The issue probably relates to the keyboard equivalents (on the Alt-J panel). With the logic in your PLC program, once you ever use Ctrl-C (forward) or Ctrl-W (reverse), then one or the other of those requests remains on until you shut down and restart. That defeats the VCP selections.
Someone with more time to spend can investigate whether this issue is present in the standard template provided with v4.59, or whether it is an old bug, or if it is unique to your particular PLC program.
;KbSpinCW_M: ctrl-c
IF Kb_c && (Kb_L_Ctrl || Kb_R_Ctrl) && AllowKbInput_M THEN SET KbSpinCW_M,
RST KbSpinCCW_M
;KbSpinCCW_M: ctrl-w
IF Kb_w && (Kb_L_Ctrl || Kb_R_Ctrl) && AllowKbInput_M THEN SET KbSpinCCW_M,
RST KbSpinCW_M
what method of updating did you use? restore report and then update wizard? or did you use the wizard and 'manually' reset the cnc configuration?
i've restored your report to my lathe, and the VCP spindle buttons work as they should.
marc, the Alt-j keyboard jog spindle control works as intended in conjunction with the VCP in my testing with the report provided.
noticed in the report that the estop is inverted, please install a proper estop switch.galyion wrote: ↑Wed Nov 25, 2020 9:38 pm I just updated my lathe to the newest cnc12. didnt go very smoothly but i was able to get everything to work. only issue im having is on the vcp the spindle reverse button acts like a momentary switch. my mill and the lathe before updating if you hit the reverse direction button it would run that way. now i have to hold it in. any ideas? i can post a video if im not being clear.
report_7804734BC55F-0529192033_2020-11-25_20-41-11.zip
I tried it on a v4.50 bench setup, and found that the VCP spindle direction buttons worked fine in manual spindle mode, until I pressed Ctrl-C or Ctrl-W (the keyboard jog panel spindle direction buttons). Thereafter, the VCP buttons didn't work in manual spindle mode. M3 and M4 in auto mode worked just fine.cnckeith wrote:i've restored your report to my lathe, and the VCP spindle buttons work as they should.
That is as I would expect, because the code quoted previously:
;KbSpinCW_M: ctrl-c
RST KbSpinCCW_M
RST KbSpinCW_M
;--Set spindle direction
;------------------Set Clockwise direction
IF ((KbSpinCW_M || SpinCWKey || SkinSpinCW_M) && !SpinAutoModeLED) || (M3 && SpinAutoModeLED)
THEN RST SpindleDirection_M
IF !SpindleDirection_M THEN (SpindleCWLED), (SelectSpindleCW)
;---------------Set Counterclockwise direction
IF ((KbSpinCCW_M || SpinCCWKey || SkinSpinCCW_M) && !SpinAutoModeLED) || (M4 && SpinAutoModeLED)
THEN SET SpindleDirection_M
IF SpindleDirection_M THEN (SpindleCCWLED), (SelectSpindleCCW)
This bug is not unique to galyion's PLC program. It is present, at least, in the template source file included with v4.50. It should be fixed, by changing the keyboard jog panel code to handle Ctrl-C and Ctrl-W like it handles all other combinations:
;KbSpinCW_M: ctrl-c
IF Kb_c && (Kb_L_Ctrl || Kb_R_Ctrl) && AllowKbInput_M THEN (KbSpinCW_M)
IF Kb_w && (Kb_L_Ctrl || Kb_R_Ctrl) && AllowKbInput_M THEN (KbSpinCCW_M)
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
galyion,galyion wrote: ↑Wed Nov 25, 2020 9:38 pm I just updated my lathe to the newest cnc12. didnt go very smoothly but i was able to get everything to work. only issue im having is on the vcp the spindle reverse button acts like a momentary switch. my mill and the lathe before updating if you hit the reverse direction button it would run that way. now i have to hold it in. any ideas? i can post a video if im not being clear.
Do not use the keyboard short cuts Alt-J
Using VCP Spindle control section, can you control the spindle as expected?
A video clip of what you are doing would be helpful.
As Marc (cncsnw) pointed out, you may have found a small bug if/when you are using the keyboard short cuts (Alt j)
The bug will show up if you press Ctrl-C or Ctrl-W, even if you do not activate the keyboard jog panel with Alt-J.
A PC old-timer might instinctively press Ctrl-C thinking to interrupt whatever task is going on, without realizing it is a keyboard spindle control combination.
