so i updated my software to 4.5 snipped all my settings re-entered everything, now the steppers wont move. the cnc12 software says all is good and when i move the axis in the program the numbers move and such, but no real world movement on the cnc.
any help would be awesome. i attached the report as it sit right now, i wont change anything until i get any info on what needs to change.
thank you in advance.
RKM
updated software now no stepper movement (Resolved)
Re: updated software now no stepper movement
i just had this same issue. did you set the correct connection db25 or screw terminal. if that's not it check your enable pins
Jeremy
Pittsburgh, PA
Pittsburgh, PA
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Did you resolve this issue?RKM 3D Designs wrote: ↑Wed Nov 25, 2020 3:38 pm so i updated my software to 4.5 snipped all my settings re-entered everything, now the steppers wont move. the cnc12 software says all is good and when i move the axis in the program the numbers move and such, but no real world movement on the cnc.
report_0035FF8A51A7-0821203657_2020-11-25_14-30-59.zip
RKM
You didn't provide much information. What drives you have, where they were connected, you could have posted your screen shots BEFORE the upgrade and AFTER the upgrade.
Are you connected to Acorn DB25 or headers?
The report is not enough...
yeah got this resolved sorry fell off the map there. all good machine rocks super good now.
