Motor tuning issues
- CNC Control System Serial Number: unknown as of yet
Motor tuning issues
My machine is a Milltronics Partner 00 knee mill. I've changed the control to the All-in-one DC. I'm having a hard time getting the z-axis to be "stable" - it keeps tripping the e-stop circuit.
I thought maybe tuning it would solve it, but I'm unable to get the program to run very long. And suggestions are appreciated! I'm stumped!
I added a video showing what I'm doing and what's happening.
Thanks!!
-Ben
Thanks!!
-Ben
Re: Motor tuning issues
What error messages are displayed in the message window? Please see this post viewtopic.php?f=64&t=383 so we have the information to help you. Without even seeing how the axis is mechanically set up and just watching buttons being pressed, I would guess your axis is binding in the up direction.
I'm sorry about that! Here's the info requested. I reset my PID for the z-axis back to the defaults before generating the report, but it's still not working properly.
-Ben
-Ben
- report_0307181920_2020-09-18_07-47-45.zip
- (5.76 MiB) Downloaded 147 times
Here are some photos of the machine. The z-axis is not just the quill - it moves the whole head of the machine. I'm wondering if the weight has something to do with why it's only having issues in Z+ direction?
Here's the machine. Here's a view of the back of the z-axis, showing the linear rails and ballscrew. Here's a piece I was able to face the other day, when I first got the machine moving. It kicked out the z-axis a bunch, but I got it to run. -Ben
If there's no counterbalance on the head, then that is most probably the issue. You can try to adjust the axis acceleration down and see if that helps, but that much weight definitely needs to be counterbalanced.
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Interesting, I had never seen a Milltronics mill with that configuration.
Since Milltronics built it that way, it probably has a very large Servo motor on it and its probably geared low.
You never posted motor label information, that would be handy.
When you "TUNE" using the Centroid utility, for the most part, all the control is doing is setting acceleration.
I suggest if you have good wifi to the machine, you contact Marc Leonard (CNCSNW) via PM and ask him to see if he could remote in to tune your servos.
Of course he has a fee to do this. Its what I would do.
Oh interesting! I didn't think about the acceleration rate. I'll look into that - if I can't get it in the next hour or so, I'll reach out to Marc - thanks Marty!!
On the counter balance, I've not modified anything, so I believe it should work as-is (mechanically anyways). Here's the data plate on my z-axis motor in case anyone wants to see.
-Ben
-Ben
Here's another video of trying to adjust acceleration - you can see it works decent when I have the feed rate at 20% but even at 50% it kicks out.
And what happens when you slow the acceleration down to .1 or .2?
From the documentation, it says that the lower the number (i.e. .1) the faster the acceleration...
"6.8 MANUALLY TUNE THE ACCELERATION
Acceleration is the time for the axis to reach maximum velocity. An acceleration rate of 0.1 second is very fast, where an
acceleration rate of 1.0 will be considered very slow. CNC12 defaults to an acceleration of 0.5."
So, I didn't try anything below the default .5 - from what you said " ... slow the acceleration down to .1 or .2" - is the documentation wrong?
Thanks!
-Ben
Thanks!
-Ben
