No stepper movement
davidjaz
No stepper movement
Post by davidjaz »
I'm probably missing something obvious here, but I can't get any motor movement. When I start up CNC12, my stepper motors lock. When I try to Jog the DRO shows that my axis are moving but nothing happens. The motors make a click like they are power cycling when I hit the jog buttons, but nothing.
I am using generic Chinese Motor drivers and am set to the Leadshine configuration. I turned off Input 5 because I don't have a "drive OK" output on the drives. I also tried to jumper to the common, and no difference.
Any suggestion where I should start troubleshooting this would be greatly appreciated.
Jaz
Chaz
Re: No stepper movement
Post by Chaz »
Post a report and some screenshots of your wizard settings, that would help a lot.
Jay Morris
Post by Jay Morris »
Do this and they should work just fine
viewtopic.php?f=60&t=3927#p31310
davidjaz wrote: Sun Jan 26, 2020 3:39 am I'm probably missing something obvious here, but I can't get any motor movement. When I start up CNC12, my stepper motors lock. When I try to Jog the DRO shows that my axis are moving but nothing happens. The motors make a click like they are power cycling when I hit the jog buttons, but nothing.
Jaz
Happy to help, but you don't provide enough information.
PLEASE follow this: viewtopic.php?f=60&t=3539
I would disconnect enables and see if they move. But you don't give enough information for us to help you so that's a shot in the dark.
Remember, "We can't SEE what you SEE"
Richards
Post by Richards »
You have the Enable signal wired to the drive. On my stepper drives, if I use the enable signal, it actually disables the drives. On my servos, I have to have enable working for the motors to spin.
-Mike Richards
davidjaz
Post by davidjaz »
Thanks for all the input. I think I found the problem. My drives and motor are about 10 years old. They are still new in the box never used. These drive are supposed to be set to 35,000 HZ. They were set to 200,000Hz. I changed it to 100,000 Hz and I got some slight movement and they stopped. I can't find a way to set the drivers lower than that. Is there a way to change it manually, or do I need to buy newer drives?
Jaz
Yes it's possible, but I'd buy new drives.
You never said what brand and model they were along with the rest of the information requested
Gary Campbell
Post by Gary Campbell »
Do test and connect them to the DB25 header. You can also set, I think, parm 186 to a lower number than 100k.
Doesn't make them any newer or eliminate the need to replace them, but may give some satisfaction
PARAMETER 968= Pulse/Step Frequency(Hz
0 = 200000
1 = 1200000
2 = 600000
3 = 400000
4 = 300000
5 = 240000
6 = 200000
12 = 100000,
30 = 40000
60 = 20000
100 = 12000
Gary Campbell
Thanks for the save Marty...I better look those numbers up next time
