Problema de configuracion ACORN
Oswaldo
CNC Control System Serial Number: Acorn180322
Post by Oswaldo »
Already present the case where, referring to the motors not turning, I count the elements that I have for my machine:
The machine I own is a Millport ref X635. the screws are re-circulating balls 32 mm in diameter and 5 mm pitch. The Z axis has a reduction by gears 18 to 36 teeth bevel gears.
I have installed a YASKAWA speed variator V1000 2.2 KW.
The engines and Draiver that I am using are of the DMM brand ref 640 DTS of 400 Watts, for the X, Y, Z and Fourth axis.
I use the ACORN card with the V-4-18 software which is the last one that came out.
I have installed the 6 NPN limit switches to control the 3 axes connected in series, starting with the axis -Z, -Y-, -X, according to the plans supplied by Centroid.
The choice of engine power is because the engines I use on the X, Y axes are 200 watts at 200 RPM.
In the tests that I have done with the DMM software of which I attach the image, the motors rotate in both directions and I do the other movement tests, saving the readings that are obtained and pressing on PULSE / DIRECTION, saving the changes.
When I go to the From the Centroid card program with the configuration attached in the following images, none of the motors rotate in any way.
Change in the DMM GEAR Number program to 2000 and in Centroid to 8000 steps.
I still can't get the engines moving.
Read I appreciate your collaboration
Sincerely,
Oswaldo
Ya presente el caso donde, hacia referencia a que no giran los motores, hago un recuento de los elementos que tengo para mi maquina:
La maquina que poseo es una Millport ref X635. los tornillos son de bolas re circulantes de 32 mm de diámetro y paso 5 mm. el eje Z tiene una reducción por engranajes 18 a 36 dientes engranajes cónicos.
Tengo instalado un variador de Velocidad YASKAWA ref V1000 de 2.2 KW.
Los motores y Draiver que estoy utilizando son de la marca DMM ref 640 DTS de 400 Watios, para los ejes X, Y, Z y Cuarto eje.
Utilizo la tarjeta ACORN con el software V-4-18 que es la ultima que salio.
Tengo instalados los 6 finales de carrera NPN para controlar los 3 ejes conectados en serie, empezando por el eje -Z, -Y -, -X, deacuerdo a lo planos suministrados por Centroid.
La elección de la potencia de los motores es por que los motores que utilizo en los ejes X, Y son de 200 watios a 200 RPM.
En la pruebas de que he hecho con el software de DMM del que adjunto imagen los motores giran en los dos sentidos y hago las demás pruebas de movimiento, guardando las lecturas que se obtienen y pulsando en PULSO/ DIRECCIÓN, guardando los cambios.
Cuando paso al programa De la tarjeta de Centroid con la configuración que adjunto en las imágenes siguientes, ninguno de los motores giran en ningún sentido.
Cambie en el programa de DMM GEAR Number a 2000 y en Centroid a 8000 pasos.
Aun no logro que se muevan los motores.
Lea agradezco su colaboración
Atentamente,
Oswaldo
report_38D2694D649E-0626181014_2019-09-27_10-21-41.zip
(292.53 KiB) Downloaded 117 times
Re: Problema de configuracion ACORN
hello. too much connected at once.. connect one thing at a time. drop back to basic connection.
disconnect the home switches. and remove them from the Wizard input 1
post a screen shot of the "advanced" menu in the wizard.
install a working Normally Closed Estop switch.
are you using the DB25...please post photos or your wiring and drives!
Bench Test Procedure
Stage 1. Communication Bench Test. Nothing but power and Ethernet cable connected
Stage 2. Connect a Normally Closed Estop. Set to NC in Wizard on input 8, verify proper Estop operation.
Stage 3. Connect one drive and motor. Verify motion
Stage 4. Connect Home Switch to HomeAll on input 1. verify proper operation in Alt i screen (input and output screen) in CNC12
Stage 5. Connect and configure other accessories and test.
WHICH DMM Drives do you have? DYN2 or DYN4?
I seem to remember you had DYN2 from a previous picture.
PLEASE take NEW pictures of your cabinet wiring.
PLEASE, GO TO YOUR DRIVE, write down or draw exactly how you wired it up.
You said you inverted your STEP settings in another post in order to get the motors to move.
That seems to indicate you miswired the STEP circuit. Go back and closely look at how you wired the drive and report back here.
DO NOT POST IN SOMEONE ELSES POST, it confuses things. We will try and help you here.
DanielCA92563
Post by DanielCA92563 »
Oswaldo,
I'll bring the conversation back to your thread to avoid confusion as Marty suggested. I should have replied to you here.
So you have DYN-2 Drives.
Can you post detailed pics here of all your cable connections.
My youtube channel is Daniel M
I actually have to wire and bench test a couple of of DYN2s for my lathe conversation, I'll be sure to make a video of how I connected them and the bench testing. It might be a few days since I'm a little busy this weekend.
-Daniel
DanielCA92563 wrote: Sat Sep 28, 2019 1:18 pm Oswaldo,
-Daniel
Thanks so much for the assist Daniel!
Oswaldo,
I may have found an issue.
Can you set your step rate to 200KHZ and UNCHECK your Step and Dir inversion boxes. Will your motors turn in both directions?
You MAY have to check or Uncheck the ENABLE box. YOu may note when you save it, exit the Wizard. Then come back into the Wizard, the Enable box may be the opposite of what you had it previously. BUT do please try at 200KHZ and let me know what you find.
