Acorn expansion board
- CNC Control System Serial Number: many boards
Hi,
Please, what is the status of the expansion 1616 card for Acorn ?
\PLData
\PLData
Re: Acorn expansion board
very close to beta software for beta testers. sorry its taken so long.. lots and lots of changes in the background to support it.
in mean time here are some docs to look at.
- Ether1616_overview_rev3.pdf
- (6.4 MiB) Downloaded 339 times
- ETHER1616,1-PHASE_To_3PHASE_MOTOR_CONNECTIONS-DRAFT.pdf
- (142.53 KiB) Downloaded 251 times
- S15003-ETHER1616,TYPICAL_CONNECTIONS-DRAFT2.pdf
- (160.35 KiB) Downloaded 263 times
WOW! That is a real game changer for Centroid and the Acorn. It was quite a challenge to get all the functionality required on my system within the IO limitations of the base Acorn. I can't wait for this to be released and put it to work on my ATC which currently requires more IO than I have left over.
It's definitely worth taking your time to test and debug this before release but you can be certain there is an eager user base out here waiting for it. This will breath a whole load of extra life into the Acorn range!
thanks.. yes. we plan on having an open beta period as well. this will be a first for us..
so, after our testing with the beta test crew, we will publish a public beta here on the forum of what will become v4.20
this way we can make any final tweaks before releasing an official 4.20 version.
Hi Keith,
Many thanks for sharing this information to the forum, It help the wating time,
and I is looking forward to order it
\PLData
\PLData
- CNC Control System Serial Number: 38D2695C8301-0122180576
Being able to have up to three of these opens up a lot of possibilities. The router I am refitting has a remote PLC on the z-axis to handle I/O for the proximity switches and the tool changer. Now I will be able to replace the PLC with an Ether1616 and not have to extend all the wires back to the Acorn... Very, Very Cool!
Clint in NW Arkansas
I too am looking forward to the board. It is like waiting for Christmas morning to arrive when you where a child. I check every day couple times a day to see if it has been released.
- CNC Control System Serial Number: 38D2697C7838-0522180924
That would be a total of 24 input and output?.
More than double that, the PDF said up to three of the Ether1616 will be supported by Acorn. So that is 48, plus the 8 on the Acorn for a total of 56 inputs and 56 outputs!!!
I was searching Google looking for commercially available Din Rail mounts for the Acorn, and look what I found instead!
Draft Ether1616 Setup Guide
