Shopsabre pro3636 converted to ethercat + Oak
DannyB
CNC Control System Serial Number: A900712
Post by DannyB »
This was originally a WinCNC machine, with an old mitsubishi PLC controlling the spindle and some relay boards controlling the pneumatics.
I got amazingly tired of WinCNC and the limitations it has. I also wanted more Z-axis travel, so i rebuilt the Z-axis.
Everything (pneumatics, VFDs for pump/spindle, I/O) is now ethercat, except for the servos, and the spindle (the interface is on order).
The ethercat I/O is mirrored to the right OAK inputs, but come from elsewhere - the VFDs are mounted far away with nothing but power and ethernet ;)
The pneumatic actuators are not on random parts of the Z axis with wires running in the e-chain.
I hear someday in the future i may be able to use ethercat servos with centroid , and maybe use ethercat I/O :)
It would remove 90% of the wires you see here.
Re: Shopsabre pro3636 converted to ethercat + Oak
right on! thanks for posting!
yeah..rumors are true! we are working on the "Hickory" CNC controller that uses Ethercat communication!
what axis servo drives/motors are you using?
DannyB
Post by DannyB »
These are yaskawa sigma-7 with motors that have the new batteryless absolute encoders.
They are being run in incremental encoder mode.
I actually have a bunch of sigma-7 ethercat versions lying around, just waiting for hickory ;)
killer.. great drives!
