ALL Acorn Documentation
Locked
Acorn CNC controller Start Here setup webpage and videos.
https://www.centroidcnc.com/centroid_di ... guide.html
Acorn "Start Here" sheet included with all Acorn kits.
https://www.centroidcnc.com/centroid_di ... t_here.pdf
Acorn Installation Manual.
AcornSix Installation Manual
How to Configure Windows 10/11 for CNC control use.
https://www.centroidcnc.com/dealersuppo ... ds/309.pdf
All Acorn CNC controller Hookup Schematics: Use the search to narrow results "acorn" , "leadshine" , "plasma" etc.
https://www.centroidcnc.com/centroid_di ... browse.php
Centroid CNC12 Mill, Router, Lathe and Plasma Software Download:
Acorn CNC12 parameters list see the updated CNC12 v5.0 Mill and Lathe operators manuals (links below) the CNC12 parameter section of the manual has been updated with Acorn and AcornSix related parameters. (Note: The AcornSix and Acorn Wizard will set these parameters for you.)
Centroid Mill Operator Manual
CNC12 Router Operator Manual
Centroid Lathe Operator Manual
Acorn Probe Setup Guide
https://www.centroidcnc.com/centroid_di ... _setup.pdf
Centroid TT-4 Tool Touch Off Probe Users Manual.
Centroid KP-3 Touch Probe Users Manual.
https://www.centroidcnc.com/centroid_di ... _probe.pdf
Acorn Axis Pairing and Auto Squaring Guide
https://www.centroidcnc.com/centroid_di ... _guide.pdf
Teknic Clearpath Hard Stop Homing and Autosquaring.
https://www.centroidcnc.com/dealersuppo ... ds/320.pdf
Acorn Laser Hookup, Setup and Sync Test instructions
https://www.centroidcnc.com/dealersuppo ... ds/326.pdf
Acorn Wireless MPG
https://www.centroidcnc.com/centroid_di ... ss_mpg.pdf
Acorn Plasma Wireless MPG
https://www.centroidcnc.com/centroid_di ... WMPG-4.pdf
Ether1616 Setup Guide
Introduction to Centroid CNC Macro Programming
https://www.centroidcnc.com/centroid_di ... amming.pdf
Centroid VCP 2.0 Users manual
Tool Height, WCS Part Zero, Machine Coordinate explanation
https://www.centroidcnc.com/centroid_di ... rement.pdf
Related posts. WCS made easy. https://www.autodesk.com/products/fusio ... made-easy/
and Machine Axis Convensions: viewtopic.php?p=28437#p28437
Acorn G-code Smoothing User Manual
Acorn CNC12 Acorn Wizard Input and Output “canned” PLC functions and M codes
Acorn_rev4 CNC Controller Specifications Manual (current shipping Acorn control boards are revision 4 (rev_4))
Acorn Machine Tool Safety Device configuration. (door switches and door interlocks, discussion of other types as well such as light curtains, foot pedals etc)
https://www.centroidcnc.com/centroid_di ... erlock.pdf
Acorn 8 Relay Module data sheet.
https://www.centroidcnc.com/centroid_di ... asheet.pdf
Using the CNC12 PLC Input Output diagnostic screen documentation.
https://www.centroidcnc.com/centroid_di ... screen.pdf
Acorn Encoder basics, setup and Rigid Tapping Parameters.
viewtopic.php?p=8876#p8876
All Centroid CNC control related Solid Models.
https://www.centroidcnc.com/centroid_di ... models.zip
Acorn Plasma
Acorn CNC12 Plasma Post Processor.
centroid_plasma_thc_sheetcam.zip
(1.37 KiB) Downloaded 657 times
Acorn Plasma User Manual.
Offline Plasma Intercon installer
DIY CNC Gear we use but don't sell.
Acorn CNC controller buyers FAQ
https://www.centroidcnc.com/centroid_diy/acorn_faq.html
Teknic Clearpath setup guide.
viewtopic.php?f=60&t=5531
Delta AC servo drive for Acorn use Setup instructions.
https://www.centroidcnc.com/dealersuppo ... ds/303.pdf
Yaskawa AC Servo drive setup for Acorn use.
https://www.centroidcnc.com/dealersuppo ... ds/307.pdf
Two Acorn CNC Forum categories with specific information in both text and video format have been setup.
Please review these knowledge base forums for info on specific Acorn subjects.
Acorn Technical How-To CNC Videos http://centroidcncforum.com/viewforum.php?f=61
Acorn Technical Tips on specific CNC subjects http://centroidcncforum.com/viewforum.php?f=63
Acorn CNC Logo in .DXF, .DWG and .SVG
https://www.centroidcnc.com/centroid_di ... c_logo.zip
Centroid logos are at the bottom of this page.
https://www.centroidcnc.com/news_media.html
Acorn How-To YouTube Channels
Centroid Technical Support YouTube Channel.
https://www.youtube.com/user/CentroidSupport/videos
Marty's CNC Garage YouTube Channel.
https://www.youtube.com/channel/UCTNt9I ... GVQ/videos
How to effectively search for information: Use the Advanced SEARCH feature of this forum to find previous posts that contain good information on the subjects you are interested in.
Choose the "Advanced Search" by clicking on the Gear Icon for a selection of searching option tools which help you find what you are looking for.
Use the features in the Advanced Search to narrow down choices.
Archival Documentation.
Centroid CNC12 v4.82 Mill, Router, Lathe and Plasma Software Download:
Acorn CNC12 v4.80 ATC programs and instructions
https://www.centroidcnc.com/centroid_di ... ograms.zip
Centroid Acorn CNC12 v4.80 release notes.
https://www.centroidcnc.com/centroid_di ... _notes.pdf
Centroid Acorn CNC12 v4.80 update instructions.
Alternative operator controls via keyboard emulators.
https://www.centroidcnc.com/centroid_di ... ntrol.html
and
Contour Shuttle.
https://www.centroidcnc.com/centroid_di ... uttle.html
Old Legacy Acorn Schematics for Acorn units sold in 2017/2018
https://www.centroidcnc.com/centroid_di ... matics.zip
Acorn CNC12 parameter list for v4.5
https://www.centroidcnc.com/centroid_di ... meters.pdf
Acorn CNC12 v4.5 Acorn Wizard Input and Output “canned” PLC functions and M codes
https://www.centroidcnc.com/centroid_di ... ns_4.5.pdf
Locked
