Resetting to 0 after each line of code
- CNC Control System Serial Number: 1218120647
Greetings,
I finished installing an Acorn board into a DynaMyte 3300 slant bed lathe retrofitted with stepper motors.
To test my work, I was going to create 3 replacement registration popup pins for one of our CNC routers.
I created two seperate turning files with Intercon. One to turn down a .875" aluminum rod to 20mm. The other to put a shoulder on the end.
The first file ran flawlessly. The shoulder file not so much. I've attached photos of what Intercon graphed the file as and what the lathe cut.
I've also attached G-Code for both files and a Report.
It appears to me that rather than returning to Z0 after each pass, it is resetting Z0 to the end of the first pass. I can confirm that after aborting the job, Z0 was no longer at the end of the stock where I set it.
Thinking that it was a software corruption, I reloaded CNC12 v4.18 Lathe. I re-ran Intercon for the first file--turning .875" down to 20mm. This time this file behaved the same way the shoulder file did. After its first pass, it didn't return to Z0 but reset Z0 and proceeded to the next X depth.
Any insight or help you can provide is much appreciated.
Richard
Richard
- report_780473281B80-0321191802_2019-06-25_17-18-51.zip
- (282.92 KiB) Downloaded 119 times
- IMG_6139.jpg (13.12 KiB) Viewed 4804 times
- IMG_6140.jpg (43.51 KiB) Viewed 4804 times
- popup shoulder.cnc
- (1.29 KiB) Downloaded 151 times
- popup retry.cnc
- (838 Bytes) Downloaded 120 times
- pop-up.cnc
- (796 Bytes) Downloaded 124 times
Re: Resetting to 0 after each line of code
axis motors and drives being used?
loose motor to screw coupler?
loosing steps on the rapid retrack move?
Your pictures are very small, can't see much detail. Take them in higher resolution like 640x480 or so.Exhibitology wrote: ↑Tue Jun 25, 2019 5:22 pm Greetings,
Richard
Post the intercon file .icn created as well.
Thanks for the quick reply.
The motors are Keling KL34H2160-62-8A wired bipolar at 4.4 amps at 61 VDC.
The drives are Pacific Scientific 6410's at 1/16 microsteps.
The couplings are solid.
Just in case, I halved my maximum job rates.
It is definitely not loosing steps. It is resetting my Z zero work coordinate. You can watch it in real time.
It has to be something I'm doing wrong in Intercon. I have one file that works correctly and one goes haywire. One file,
All the while, it has also reset the machine position's Z axis Zero point. After loading and running
I went thru this three times. Home machine, Zero X and Z, load and start
I've attached screen shots of my Intercom turning screen. You'll probably see something that jumps right out at you. I wish I did.
Thanks for your help.
Best Regards
Richard
, correctly turns down a -1.7 inches of a .875" diameter aluminum rod to .787". The otherpopup.ItM
, starts at Zero, resets Zero 1.8" in the positive direction, goes there, resets Zero 1.8" in the positive direction, goes there, etc.popup retry.ItM
, I have to rehome my machine because machine Zero has been changed. Running again puts me out of limits.popup retry.ItM
. No problem. Load and startpopup.ItM
. Problem.popup retry.ItM
Best Regards
Richard
- IMG_6163.jpg (17.15 KiB) Viewed 4740 times
- IMG_6161.jpg (12.09 KiB) Viewed 4740 times
- IMG_6160.jpg (12.66 KiB) Viewed 4740 times
- IMG_6157.jpg (17.23 KiB) Viewed 4740 times
By changing a G99 to a G98, the files now run identically.
Previously the file with a G99 was resetting work and machine coordinates
as the G code was executed. After a cut path, instead of a rapid return
for the next cut path, home was reset to the end of the first cut path
and a new cut path would begin from there.
The lathe has an working encoder connected to the inverter that
controls the spindle.
Why would a command for feed per revolution instead of one for
feed per minute would cause the resetting of work and machine
coordinates in the Z axis.
Can you please post the intercon files? They have a .lth extension.
We'll see if we can get Centroid's lathe tech to look at this. He will want to see the Intercon files along with the G code you posted.
A video of it cutting the part would be helpful too.
We'll try and get you squared away. This area is not my forte'
Shouldn't that be "The lathe has a working encoder connected 1:1 to the spindle that is controlled by the inverter."? I don't think it will work any other way.Exhibitology wrote: ↑Tue Jul 09, 2019 4:08 pm The lathe has an working encoder connected to the inverter that
Milton in Collierville, TN
For the file popup retry.cnc running G99 - Feed per Rev you have F22 which would be 22 inches per rev. In inches per minute this would be over 6000 inches per minute. This would cause you to loose position. When using G99 the feed rate you should be like .010 - .020 per rev for roughing and .002 to .004 for finish pass to get a 32 finish or better. For the file pop-up.cnc you have the G98 in you have the feed rate at F3 which would be 3 inches per minute which .0015 feed per rev.DICKEYBIRD wrote: ↑Tue Jul 09, 2019 5:20 pm It has to be something I'm doing wrong in Intercon. I have one file that works correctly and one goes haywire. One file,
popup.ItM
popup retry.ItM
popup retry.ItM
popup.ItM
popup retry.ItM
. Problem.
Dana
Thank you. I had a hunch it had to do with the
inches per rev. setting only because if I switched
that setting the problem disappeared.
Your explanation makes complete sense.
Best Regards
Rich
Best Regards
Rich
