Intercon circle close
- CNC Control System Serial Number: K102811
when I close the circle of a circle or a oblong as in this example, Intercon puts a move on the circle. what is the procedure to stop this?
![Image]()
- 8x16 gage pin 2.icn
- (4.65 KiB) Downloaded 82 times
- 8x16 gage pin 2.cnc
- (1.68 KiB) Downloaded 108 times
Re: Intercon circle close
Don't forget to cancel cutter comp when you are done with the path, before you move X/Y anywhere else.
You probably want Comp Off after operation 19 in your example.
i finally figured out the screen shot
the two arcs going back to the left is what i am referring to![Image]()
i thought there was an auto off to the comp.
it has been since the late 80's i programmed anything like this. the pronest i used on the plasma i programmed did all of that for me.
looking at the .icn program.. the comp was never turned off.
i go over how to program intercon and cutter comp in detail in the mill training video.
viewtopic.php?f=61&t=2118
