Using DP-4 and TT1 to set tool offsets on a knee mill
Supermax knee mill. About 4.25" of travel in Z
What is the proper procedure to use DP-4 touch probe and a TT1 to set tool offsets. Using DP-4 as the reference tool?
Thanks in advance
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Re: Using DP-4 and TT1 to set tool offsets on a knee mill
Post by Nigelo »
Hi Marty
Not sure if this is the 'correct' way for the conductive TT1 on a knee mill but I use my DP4 with the mechanical TT2 (on a turrent mill) as follows:
With the DP4 mounted and connected and the TT2 in its reference position but NOT connected, effectively I touch off the DP4 and set both the reference tool position as well as storing it as tool #10. For sure there are other ways of doing this with the TT2 as its mechanical but as the TT1 is conductive and the DP4 being tipped with a ruby, I don't see any other way for you. Out of interest, this was one of the reasons I finally went for the TT2.
Hope this helps and thanks again for all YOUR help
Nigel
Hope this helps
Nigel
Nigelo wrote: Tue Jun 04, 2019 5:26 am Hi Marty
Nigel
Thanks Nigel, using this combination is new to me.
I help when and where I can. Thanks!
