bench test problems
donm
CNC Control System Serial Number: XHGBFHDABH
bench test problems
Post by donm »
just setting up and doing a bench test on a new oak install
all went well except when i push start the analog output goes up to the correct voltage and then shuts off after about 2 seconds. i have to e-stop then hit start again and 2 seconds later it shuts off. i change the speed settings and the analog value changes but still only runs for 2 seconds. there are no alarms that come up.
report_0320190765_2019-05-06_11-51-21.zip
(239.06 KiB) Downloaded 77 times
Re: bench test problems
Please check out this thread and watch Marty's video and report back
viewtopic.php?f=20&t=2931&start=30
donm wrote: Mon May 06, 2019 2:08 pm just setting up and doing a bench test on a new oak install
It doesn't seem to me that you followed the Oak installation manual. In looking at your log file:
(1) 05-03-2019 14:44:24 204 Exiting CNC...Normal Exit (66)
(1) 05-06-2019 8:26:17 199 CNC Started
(1) 05-06-2019 8:26:20 406 Emergency stop detected
(1) 05-06-2019 8:26:21 CNC12-D Mill v4.14
(4) 05-06-2019 8:26:21 2099 Message Cleared
(4) 05-06-2019 8:26:22 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 8:26:35 4032 Reset Cleared
(1) 05-06-2019 8:26:38 412 Spindle axis(6) encoder differential error
(1) 05-06-2019 8:28:06 Creating report...
(1) 05-06-2019 8:28:11 Saved report to C:\cncm\report_0320190765_2019-05-06_08-28-06.zip
(1) 05-06-2019 8:30:06 204 Exiting CNC...Normal Exit (66)
(1) 05-06-2019 9:04:40 199 CNC Started
(4) 05-06-2019 9:04:42 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 05-06-2019 9:04:42 412 Spindle axis(6) encoder differential error
(1) 05-06-2019 9:04:43 CNC12-D Mill v4.14
(4) 05-06-2019 9:04:43 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 05-06-2019 9:04:45 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 9:05:24 4032 Reset Cleared
(1) 05-06-2019 9:05:27 412 Spindle axis(6) encoder differential error
(1) 05-06-2019 9:05:28 412 Spindle axis(6) encoder differential error
(1) 05-06-2019 9:08:34 204 Exiting CNC...Normal Exit (66)
(1) 05-06-2019 9:30:14 199 CNC Started
(4) 05-06-2019 9:30:16 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 05-06-2019 9:30:16 412 Spindle axis(6) encoder differential error
(1) 05-06-2019 9:30:17 CNC12-D Mill v4.14
(4) 05-06-2019 9:30:17 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 05-06-2019 9:30:19 9033 Reset Initiated, Press Reset to Clear
(1) 05-06-2019 9:37:31 204 Exiting CNC...Normal Exit (66)
(1) 05-06-2019 10:22:10 199 CNC Started
(4) 05-06-2019 10:22:13 9033 Reset Initiated, Press Reset to Clear
(1) 05-06-2019 10:22:13 412 Spindle axis(6) encoder differential error
(1) 05-06-2019 10:22:14 CNC12-D Mill v4.14
(4) 05-06-2019 10:22:14 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 05-06-2019 10:22:14 2099 Message Cleared
(4) 05-06-2019 10:22:14 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 10:22:39 999 Parm #313 modified: 6.00000 -> 0.00000
(1) 05-06-2019 10:23:19 Exiting CNC and shutting down machine (68)
(1) 05-06-2019 10:26:03 199 CNC Started
(4) 05-06-2019 10:26:06 9033 Reset Initiated, Press Reset to Clear
(1) 05-06-2019 10:26:07 CNC12-D Mill v4.14
(4) 05-06-2019 10:26:07 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 05-06-2019 10:26:07 2099 Message Cleared
(4) 05-06-2019 10:26:07 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 10:26:11 4032 Reset Cleared
(4) 05-06-2019 10:26:13 501 Invalid character, TT1LOC.CNC, line 17
(4) 05-06-2019 11:44:41 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 11:44:47 4032 Reset Cleared
(1) 05-06-2019 11:45:12 406 Emergency stop detected
(1) 05-06-2019 11:47:54 Creating report...
(1) 05-06-2019 11:47:59 Saved report to C:\cncm\report_0320190765_2019-05-06_11-47-54.zip
(4) 05-06-2019 11:48:54 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 11:48:55 4032 Reset Cleared
(4) 05-06-2019 11:49:00 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 11:49:01 4032 Reset Cleared
(4) 05-06-2019 11:49:35 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 11:49:36 4032 Reset Cleared
(4) 05-06-2019 11:49:59 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 11:50:00 4032 Reset Cleared
(4) 05-06-2019 11:50:24 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 11:50:25 4032 Reset Cleared
(4) 05-06-2019 11:50:54 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 11:50:55 4032 Reset Cleared
(4) 05-06-2019 11:51:04 9033 Reset Initiated, Press Reset to Clear
(4) 05-06-2019 11:51:05 4032 Reset Cleared
(1) 05-06-2019 11:51:21 Creating report...
You finally turned off the spindle encoder. Then after that you tried to load a file with a bad character TT1LOC.CNC
I suggest you back up to the beginning and follow the Oak installation manual and take it one step at a time. If you get tripped up. Tell us exactly what part you got hung up on and at that point create and post a fresh report.
If you get through it, then let us know what the problem was and that it is resolved.
